rearend?
Old Mar 24, 2010 | 07:22 PM
White Ghost's Avatar
rearend?
can i use a rearend out of a 2500 dodge? mine is going out and i can pick up this one up real cheap. let me know what i can do .thanks
Old Mar 24, 2010 | 07:25 PM
annabelle's Avatar
year?
Old Mar 24, 2010 | 07:41 PM
megacabdad's Avatar
Is your truck a 4x4?
If so, the gear ratio must match the one in the front diff.
If your truck is a 4x2, you can make just about any axle work.
Old Mar 24, 2010 | 07:44 PM
Crobar's Avatar
Same rear axle in 2500/3500
Just match ratio and you are all set.
Old Mar 24, 2010 | 08:18 PM
my truck is a two wheel drive. the 2500 is an 05
Old Mar 24, 2010 | 08:24 PM
megacabdad's Avatar
You should be good to go then.
Old Mar 25, 2010 | 12:28 AM
annabelle's Avatar
^^x2
Old Mar 25, 2010 | 08:59 AM
i am sorry the truck is an 03 2500 . does this make a difference? it does have disc brakes on the the rearend. let me know. thanks for the help.
Old Mar 27, 2010 | 12:39 AM
Thumbs up
well i picked up the rearend for 450.00. when i got it home i opened it up and it is a posi with 4.10 gears. i bought it from a kid that did not know what he had. lucky me.
Old Mar 27, 2010 | 07:13 AM
megacabdad's Avatar
That sounds like you got a pretty good deal.
Old Mar 27, 2010 | 01:04 PM
Unhappy
how do i make this rearend work with my dual rear wheels? i just don't see how it is going to work . am i missing something?
Old Mar 27, 2010 | 01:17 PM
megacabdad's Avatar
Where did the dually come into play at?
Old Mar 27, 2010 | 01:33 PM
the truck is in my sig.it is ok i am just going to sawp the interal parts.it still ended up being a good deal. i should have made things more clear in my first post
Old Mar 27, 2010 | 01:39 PM
megacabdad's Avatar
I didn't know it was a DRW...your sig. just says 3500...Oops.
abb
Sep 13, 2003 01:13 PM
Pontiac puller
Sep 10, 2003 08:51 AM
sshelly
Jun 23, 2003 11:34 PM
big b
Nov 10, 2002 03:50 PM
ronster
Nov 1, 2002 04:14 AM
