Metal shavings on rearend plug
Good morning all, another noobie question. I pulled the plug on my rearend and there was a bunch of small metal shavings on the magnet, is this normal for anti-slip differentials? there is 70K on the truck. :P
Re:Metal shavings on rearend plug
Not know the size of the shavings, I would say yes. You should see what's on the magnet inside the cover. Mine had about 10K when I pulled it to replace with a Mag-Hytec, and the magnet was covered with a metallic mud. I'd say you're fine, but you might think about draining the rear and replacing the gear oil.
The metal on the plug was larger than the typical mud you normally find, it was actually small slivers? What is Mag-hytec?
Mag-Hytec is a specially manufactured rear gear cover, that holds an extra quart, has a built-in dipstick, and a drain plug. Very good looking, highly functional, many of us have them. Almost every diesel performance shop sells them.
I'd suggest a good synthetic gear lube like Amsoil Series 2000 75w-90, whether you go with an aftermarket cover or not.
Without getting a look at the actual size of the shavings/slivers, I'd guess that's normal, I've seen pretty much the same as you described, in 3 different truck axles, but none/or insignificant amount since switching to synthetic.
I agree with Brian, the ring and pinion is a wear part, not like bearings, there will always be some wear which is picked up (hopefully) by the magnet.
gnuesse
05-27-2007 10:21 AM
rockhound
11-02-2006 04:38 PM
JD farmboy
15
05-23-2006 03:58 PM
roughstock
04-05-2006 09:59 AM
