Rear Gear Oil Additive???
Old Jun 7, 2007 | 10:35 PM
CatDiesel_762's Avatar
When choosing a oil I would choose one that has met the OEM, MIL, ASME specs for the 3rd Gen Dodge Ram with AAM Axles. I would also choose one that I could find at local distributor. That way if I was in a pinch, at home or on the road, I will be able to find more if needed.
Shawn
Old Jun 11, 2007 | 02:38 PM
RobG's Avatar
Regarding 75W-90 vs 75W-140... any input about fuel economy with the thicker stuff? Seems like the added drag would cost 1-2 mpg.
Rob
Old Jun 11, 2007 | 04:54 PM
Jeff in TD's Avatar
No difference that I could detect...
Old Jun 11, 2007 | 07:22 PM
gus's 03's Avatar
red line shock proof 85-250 actualy has les drag than most thinner oils... probably not enough of a diferance to be mesurable in out trucks but it cant hurt.
Old Jun 13, 2007 | 08:33 PM
drolex's Avatar
Originally Posted by bekim
AAM rear ends, no additive, Dana rear ends get additive. Third the cover removal. The stock ATF +4 is semi-synthetic. Full synthetic is good stuff for the pumpkins.
Cheers
Mike
What is the additive that I need for my Dana? Should I use the same oils as already suggsted?
Elk_Hunter
Jun 13, 2010 09:41 PM
old 300
Nov 1, 2006 09:48 PM
jwhip
Jan 3, 2006 05:24 PM
Journier
Sep 23, 2005 03:41 PM
USMC64-70
Nov 10, 2002 02:59 PM
