Rear Diff. oil and friction additive
Old Oct 31, 2006 | 03:16 PM
old 300's Avatar
Just a quick question about how much oil is in the rear diff., I think mine is a Dana 70 with the anti-spin option. I was a the dealer today to pick up supplies and they were not sure the refill spec. until they looked at the computer. They told me it was about 3.6 litres and they said one bottle of additive which was 4 ounces ( 120 mil) was enough. The thing is my owners manual says to use 6.5% additive of refill cap. That would be almost 8 ounces or 234 mil. So has anyone done a refill and how much should I use. The dealer said a bit too much wouldn't hurt but not enough would cause a shutter and binding. The reason for the fluid change is the cover gasket is leaking, I found a TSB on that problem. I guess the fluid reacts with the RTV sealant and it fails.
Old Oct 31, 2006 | 06:06 PM
gunnie's Avatar
i changed mine to royal purple, no friction modifier required
Old Oct 31, 2006 | 06:10 PM
CTD2001's Avatar
I believe the dana 70 takes 7 quart, If you use one of the higher end synthetic brands of oil, ie amsoil royal purple ect, i dont think you need to use any friction modifier, if you do and some, it wont hurt.
Old Oct 31, 2006 | 08:18 PM
Devin_01's Avatar
On my Dana 80 i used 8 onces of friction modifier and a full synthetic gear oil.
Old Nov 1, 2006 | 06:54 AM
1-2-3's Avatar
Just a plain ole guy
Where do you get this friction modifier?
Old Nov 1, 2006 | 05:34 PM
old 300's Avatar
I got my additive at the Dodge store. It came in a 4 ounce bottle. I found out today that my rear axle holds almost 4 litres of diff oil with the 2-4 ounce bottles of additive. My owners manual calls for 6.5% additive as per fluid cap.
Old Nov 1, 2006 | 08:39 PM
1-2-3's Avatar
By Dodge store, you mean dealer, right?
Old Nov 1, 2006 | 09:48 PM
old 300's Avatar
Sorry my 5 year old calls the Dodge dealer the Dodge store, I guess I'm starting to talk like him. Anyway I guess you have to use the stuff or the clutches will chatter and things won't work right.
Bruce1
Mar 23, 2010 07:31 AM
arroyojim
Apr 5, 2007 12:19 AM
SIXSLUG
Nov 30, 2006 02:25 PM
Crimedog
Jun 22, 2005 04:37 PM
USMC64-70
Nov 10, 2002 02:59 PM
