rear end chatter
Old Sep 29, 2008 | 08:57 PM
rigsy340's Avatar
rear end chatter
a good friend of mine has a 07 2500 swb quad, when towing his car trailer on acceleration around corners he has rear end chatter so bad you can hear the tires hoping and rear diff binds like a spool. dealer replaced the carrier already, still has the same issue. i know these american rear diffs are "torque sensitive" and lock the inside wheels but the truck chatters so bad it feels like the rear diffs going to drop out, not so noticeable without the trailer but still there, with out the trailer the tire hops. with the trailer there planted in the ground pretty good. theres no clutches in the rear so modifier wont help. fluid is mopar 75w90. any ideas?
Old Sep 29, 2008 | 09:16 PM
Spooler's Avatar
Put the limited slip modifier in it. It has been known to solve the problem on many a truck.
Old Sep 30, 2008 | 08:04 AM
rigsy340's Avatar
is there any difference between the mopar DR and non DR oil? i will try modifier, thanks>
Old Sep 30, 2008 | 08:39 AM
05 CTD2500's Avatar
mine used to chatter real bad even unloaded with the factory fill, switched to royal purple now all is fine.
Old Sep 30, 2008 | 10:03 PM
Raspy's Avatar
I switched to 75-140 to fix mine
Old Sep 30, 2008 | 10:59 PM
westcoaster's Avatar
I put friction modifier in mine and now it's not as noticable.
creacy22
Jan 31, 2010 02:13 PM
green318
May 21, 2007 10:17 AM
Fenderstrat72
Jan 3, 2004 07:02 PM
Fenderstrat72
Dec 31, 2003 10:12 PM
Johnny
Dec 19, 2003 04:33 PM
