Rear end chatter
Old Dec 18, 2003 | 11:31 AM
Johnny's Avatar
Rear end chatter
2001 CTD 2500 QuadCab with anti-spin differential.
Last year added a Mag-Hytec diff cover for extra fluid capacity since we do lots of fifth-wheel towing. Lately when unloaded going around corners the rear end seems to chatter some and the inside wheel will spin a little. Especially noticible in a right turn where the radius is tighter. The chatter can be felt in the cab. When I installed the diff cover I added the correct amount of anti-spin diff fluid. Any suggestions what it could be? It's still in warrenty but haven't contacted the local dealer for repair.
Old Dec 18, 2003 | 11:37 AM
Dieseldude4x4's Avatar
Re:Rear end chatter
Go find a big empty parking lot and do about 18 or 20 very tight figure eight turns and see if it loosens up and quits. You may not have worked the anti-spin fluid into the clutches enough when you changed the fluid.
Old Dec 18, 2003 | 11:45 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Rear end chatter
I'll 2nd that.
Old Dec 18, 2003 | 12:25 PM
Johnny's Avatar
Re:Rear end chatter
Thanks for the suggestion. However, as I wrote, this was over a year ago that I added the fluid and changed the cover. Can the additive wear out? Is adding more now an option? Or should I drain completely and start with fresh lube and additive? I've heard of making tight figure 8's and adding a little additive till the chattering stops.
Old Dec 18, 2003 | 12:45 PM
Shovelhead's Avatar
Re:Rear end chatter
As the clutches wear, you might need to add a little more "Juice" to quiet them back down.
I'd add about 1/2 a package and "Do the 8s"
Old Dec 18, 2003 | 02:51 PM
Johnny's Avatar
Re:Rear end chatter
Thanks again for the advice. I'll be trying out your suggestions this weekend.
Old Dec 19, 2003 | 04:33 PM
jigdog's Avatar
Re:Rear end chatter
johnny that good advice if that don't work go get the dealer to put in anew one and then try a snythetic grease it works good in most units without the addative and you will have lower temps. i have had it in for about 8k now ;D
creacy22
Jan 31, 2010 02:13 PM
rigsy340
Sep 30, 2008 10:59 PM
green318
May 21, 2007 10:17 AM
Fenderstrat72
Jan 3, 2004 07:02 PM
Fenderstrat72
Dec 31, 2003 10:12 PM
