rear diff fluid
Old Jun 24, 2010 | 01:29 PM
rodriguez7's Avatar
rear diff fluid
Does anyone know how much diff fluid our rear diffs take with a magtech cover? Does 9 quarts sound right?
Old Jun 24, 2010 | 03:10 PM
jlipskoc's Avatar
I just put a Mag on, 7.5 to 8 qts,
Old Jun 24, 2010 | 04:18 PM
rodriguez7's Avatar
Ok thanks, thats what i needed to know. At around 20 a quart for royal purple, its kinda expensive
Old Jun 24, 2010 | 04:25 PM
jlipskoc's Avatar
I used mobile1 75w-90 it was $10
140w was 19.99 for some reason, I said no way. I don't tow heavy and don't live in a super hot climate.
Old Jun 26, 2010 | 08:06 PM
neversatisfied's Avatar
does anyone know what the torque spec. is for the front and rear stock covers?
Old Jun 28, 2010 | 01:44 PM
Bankdude's Avatar
For a 2003 the manual says 24 Foot Lbs:
DESCRIPTION N·m Ft. Lbs.
Fill Hole Plug 32 24
Differential Cover Bolts 40 30
Old Jun 28, 2010 | 07:54 PM
bansh-eman's Avatar
Do not try and torque them to the spec. Many havd snapped the bolts off. Just tighten them down and they will be fine.
Old Jun 29, 2010 | 02:11 PM
slorocco's Avatar
I'm just getting ready to change my diff fluid and have a stupid question. Is there a gasket under that cover or is it just RTVd?
Old Jun 29, 2010 | 02:53 PM
alboy's Avatar
Rubber gasket,clean the top and edges of the diff as best you can to keep dirt out.
Old Jun 29, 2010 | 04:50 PM
Dr.Dizzle's Avatar
The Dodge Ram front and rear diffs have gaskets that can be re used once removed. I typically just clean or wipe down the gasket and the mating surfaces prior to placing them back on.
Old Jun 29, 2010 | 06:16 PM
slorocco's Avatar
Cool, thanks guys.
Old Jun 29, 2010 | 08:15 PM
slorocco's Avatar
Question on gear lubes. Is Mobil 1 synthetic better, worse, or just about as good as the dealer Mopar stuff? What about royal purple? The royal purple stuff has limited slip additives in it. Is that a problem?
banana
Dec 1, 2009 11:44 PM
icrider
Sep 27, 2006 03:10 PM
lawnman757
Aug 29, 2003 01:03 AM
Mark Thomas
14
Aug 18, 2003 12:20 AM
lawnman757
Aug 17, 2003 10:06 PM
