Proper way to change a Air dogg fuel fiilter?
Old Sep 27, 2011 | 12:24 PM
CACalomino's Avatar
Well i have changed two filtes on my system and i need to know if im doing something wrong when i drain out the smaller fillter via pet **** it never seams to stop draining ( gallon or so of fuel comes out and still goes) so i then close it up unscrew the fuel filter and replace it and fuel still leeks out of the fuel filter side.
So can someone tell me the right way to do this or am i always gonna have a mess all over the place everytime i change it etc
thanks
-Chris
Old Sep 27, 2011 | 12:40 PM
cbrahs's Avatar
best way to stop it from doing that (it is siphoning out of the tank because the pump is lower than the fuel level) is to put a ball valve between the pump and tank. shut valve off to service, turn valve on to run. good to go
Old Sep 27, 2011 | 08:25 PM
jhenson's Avatar
^^^^ what he said
Old Sep 28, 2011 | 12:08 PM
1-2-3's Avatar
Just a plain ole guy
and you have an antitheft device that will take just a moment to enable and if it's driven away, it won't be too far from where you left it. I just might do this to mine.
Old Sep 30, 2011 | 08:25 AM
Super Dave's Avatar
Just wait to change the filter until you are under 1/4 tank. That should be low enough to switch it out without it siphoning out. Don't open the petcock at all, just unscrew the filter and that should break the siphon. I've never had a problem doing it this way.
Bearwhiz
Mar 20, 2010 03:10 PM
CACalomino
Feb 20, 2010 12:14 AM
craftybigdog
Mar 9, 2009 08:35 PM
crash4wd
MDDTR #33
Mar 6, 2009 09:58 AM
dieselfan
Jan 23, 2007 06:26 PM
