Propeller shaft
Old Feb 23, 2017 | 02:23 PM
bishgeo's Avatar
Propeller shaft
i seen a link to buy new propeller shafts vs rebuilding in here some time ago. Anybody remember.
Old Feb 23, 2017 | 11:09 PM
KATOOM's Avatar
I'm not sure what you're referring to. The only component on the truck called a propeller shaft is the transmission input shaft, but they're not rebuild-able.
Are you talking about the driveshaft?
Old Feb 24, 2017 | 12:04 AM
bishgeo's Avatar
The shaft from transfer case to front diff is called a propeller shaft. Driveshaft is for trans to rear diff.
Old Feb 24, 2017 | 03:48 AM
KATOOM's Avatar
Learn something new every day.....
Yes, there are plenty of threads out there floating around regarding replacing u-joints. But I'm sure you may already know that the front driveshaft (sorry, propeller shaft) has a double cardan joint which is bit different than your normal u-joint set up. Rather the DC joint has a spring loaded center ball between two u-joints in a single housing.
I highly suggest not messing with this joint assembly unless you you've done them before and/or know what you're doing. For that matter, I stopped rebuilding driveshafts altogether some years ago simply because it wasnt worth my time and effort since most driveline shops charge very little to install and balance your driveshaft if you buy the u-joints from them. Then you know its right and its also balanced.....
Bankdude
ABDTR #5
16
Jul 16, 2010 12:16 AM
thejoker502
Apr 6, 2010 10:56 PM
Det 1
17
Dec 22, 2009 08:32 AM
4x4dually
Jan 5, 2007 01:07 PM
signature600
Oct 5, 2005 01:43 PM
