Rough idle
Rough idle
I recently had a coolant flush done, along with water pump and thermostat too. Yesterday I noticed it had a rough idle at the red light and that the oil pressure was lower than normal. I noticed cream color puddle under the truck after work, when I got it home I happened to pull the dipstick and realized that now I have coolant in my oil. Any suggestions on where to start looking, and how to clean out the system too.. I did notice prior to the flush, I had black tar around the radiator cap. Is this the head gasket or oil cooler??
Thanks
Cord
04 Dodge 3500 5.9
Thanks
Cord
04 Dodge 3500 5.9
If you have coolant in the oil I would strongly suggest that the truck be immediately parked until the issue is resolved. Driving it with contaminated oil could very quickly lead to a very costly engine repair. Even now, with lower oil pressure, some damage may have occurred.
My guess is that you have a bad head gasket or a cracked head. Either way, perhaps the head needs to come off for a look see.
banks twinram
May 18, 2010 08:10 PM
turbov6joe
Sep 25, 2003 10:57 AM
