Price of stock air filters
Old Sep 29, 2004 | 08:24 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Wow what a difference in dealers.....one wanted $ 38 one wanted $ 28 and I bought the same one from a third dealer for $16....now who is ripping who off...check your dealers carefully
Old Sep 30, 2004 | 09:44 AM
eswartz's Avatar
I've bought the stock Mopar Air Filters off eBay from Henson Motors in Madisonville, TX. $15 for each one plus shipping. That $16 price you got is great for a local dealer.
Old Sep 30, 2004 | 02:20 PM
Hairy1's Avatar
Yeah that's what I thought
Old Sep 30, 2004 | 02:44 PM
kimber's Avatar
I paid $31.50 .........two different dealers
Old Oct 1, 2004 | 04:56 PM
Gypsyman's Avatar
$11 and change for the Fleetgaurd filter at the Cummins dealer here in Spokane.
Old Oct 1, 2004 | 08:24 PM
Hairy1's Avatar
The fleetguard is the one that pull my filterminder down to 100 % used .....when it was new............I took it out and went to the original and all is OK now.
Old Oct 1, 2004 | 08:28 PM
Hairy1's Avatar
See this thread https://www.dieseltruckresource.com/...threadid=51313
Old Oct 1, 2004 | 09:23 PM
Gypsyman's Avatar
I noticed that they have a different prefilter facing on them. If this is a problem thier all going back! By chance did you try pulling the prefilter facing off and checking the minder pull down with the Fleetgaurd?
Old Oct 2, 2004 | 04:09 PM
Hairy1's Avatar
No I didn't.....but the new stock one from Dodge works fine about 35% when new.......the fleetgaurd pulled to 95% first thing.......gotta be less flow! Right?
Fleetguard has foam rubber backing.........Dodge has Woven stuff
Old Oct 3, 2004 | 06:28 PM
Hannibal's Avatar
I have a Purolator in mine now. It doesn't have a pre filter. After our 140 mile trip this weekend, it was only doen to it's usual 35" mark.
Old Oct 3, 2004 | 06:39 PM
surfram's Avatar
Napa gold air filters cost me about $30.
AaronT's Avatar
Hairy1: you must have had an original style with the foam on it. About a year ago Cummins and DC agreed to get rid of the foam as it was causing air flow restriction. The correct Fleetguard AF26106 does not have an inlet foam or otherwise. There might be some old stock out there yet though.
Old Oct 3, 2004 | 06:45 PM
Hairy1's Avatar
Yeah that is the same stock number for the Fleetguard I had........it had the foam layer on the bottom...........wonder if they will make good on the newer version? I bet not.......
Old Oct 4, 2004 | 06:55 PM
N.Johnson's Avatar
Whow...back up the truck! Replaced my original stock mopar filter with a new Fleetguard AF26106 from the local Cummins dealer for $14.00 that has the green 1/2" foam glued to the bottom. Filter minder never budged? No restrictions I can tell or see. By the way I pay $56.00 for Valvoline premium blue 15w40 5 gallon pail. Any difference in price at cummins south of the border?
Old Oct 4, 2004 | 07:21 PM
Hairy1's Avatar
Mr. Johnson have you run her wot up an incline and make her pull with that filter? I did and showed almost 100%.........Dodge filter showed 35 %.......my brother has an '03 also......his did the same......out his came and back to the original.
