Power Steering assist on steroids...
Old Oct 12, 2017 | 12:45 PM
anpconnors's Avatar
Hi,
My power steering is waaay to easy to turn, its like the assist has a turbo, supercharger and propane. Very sensitive and over assisting is the best was to describe it. Today the assist "turned off" for two seconds while driving. Fluid level and condition are ok. Ordered a new pump and belt. This is a reman Cardone 20-70268 (old pump, installed Oct 2012). Anything else I should have at the ready for the swap other than the pulley swap tool? @ 148,000 MI
Old Oct 30, 2017 | 09:28 AM
anpconnors's Avatar
Finally getting to this, Installed new pump, hoses, and filter, also a rebuilt Gear. Waiting for tie rods to button up, bleed, and test. Doing shocks, Sway bar bushings, and links and taking on the track bar bushings. Will post once tested to see if steering issue cleared.
Old Nov 6, 2017 | 07:46 AM
anpconnors's Avatar
Advice?
So, new pump, hoses, and rebuilt gear in. Bleed system, short test drives seems ok. Then on the way into work, steering getting harder and fluid leak. Only have $400 in parts so far. Anyone do the "upgrade" to heaver duty gear and pump? What year pump and gear am I looking for? Ah track bar and sway bar redone and in fine.
Old Nov 6, 2017 | 12:53 PM
Danderson's Avatar
My friend installed Mopar's big box steering gear.
It's super tight. Steering effort is a bit higher than stock. Definitely not a one thumb box.
He got it here. Good shop. Good tech support too.
http://www.cjcoffroad.com/Mopar-6817...68170214aa.htm
Old Nov 24, 2017 | 05:06 PM
anpconnors's Avatar
repaired
leak found, pump replaced. Holding so far. Staying with stock for now. Steering tightened up with rebuilt swaybar and track bar bushings. Have steering brace with new bearing, may install next service/oil change.
Carpenter74
May 6, 2013 07:17 AM
GCSS
Mar 22, 2011 09:32 PM
prattman
Mar 17, 2011 05:03 PM
abecker7596
Dec 22, 2008 11:49 PM
pickleddiesel
Nov 25, 2007 04:29 PM
