power steering ?
Old Sep 9, 2007 | 10:46 PM
labreck's Avatar
power steering ?
So I changed the PS fluid today and now it howles. I used valvolen +4 ATF like the manul said to (maybe not that brand) but I planed on change it 2 times to flush it good, the second time with Amziol. I ran it down the road to get all the air out but its still howling. any thoughs?
Old Sep 9, 2007 | 11:14 PM
SSminnow's Avatar
OK:
1)Use your spell check.
2)Why did you change the PS fluid?
3)Is it topped off?
4)Are you sure it said use ATF?
5)You either used the wrong fluid or not enough, if it did not howl before you changed it , and now it does.
6)That seems simple enough to me
Old Sep 9, 2007 | 11:51 PM
labreck's Avatar
Originally Posted by SSminnow
OK:
3)Is it topped off?
1) wheers the spell check
2) Im a maintnince freak
3) YES
4) yes look it up for your self
5) cheep but corect fluid, its full thats why i ran it down the road to get the air out
6)take a nap, you sound crancy
Old Sep 10, 2007 | 07:25 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
If you have a friend or know anyone at a dealer. Have them print out TSB 19-008-05 Rev A. BOL!
Chris
Old Sep 10, 2007 | 08:55 AM
SSminnow's Avatar
3) YES
1)Called a dictionary (where is)
2)Me too (maintenance)
3)OK
4)You asked the question, I should not have to look it up. (yourself)
5)You changed/did something wrong. Sounds like air in the system still, with not enough fluid. Jack both tires up off the ground. Turn the wheels in both direction, lock to lock over and over again. Fluid level should drop, add some more fluid. (Cheap, correct, it's, that's, I)
6)I did, I was (cranky)
7)
Old Sep 10, 2007 | 08:57 AM
SSminnow's Avatar
Chris
He probaly does not (nether do it) can you send him (me) a link? Thanks
Old Sep 10, 2007 | 09:51 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
It's on a restricted site, but I will gladly send it by pm. Your idea of raising the front tires is part of the procedure. It just adds a hand vacuum pump into the procedure.
Chris
Old Sep 10, 2007 | 10:14 AM
SSminnow's Avatar
Chris
Cool. Thanks for the info.
Sorry to labreck if I come off rude. Spelling is just one of those things that drives me utterly insane if done incorrectly, and has since the 1st grade. No kidding there
Old Sep 10, 2007 | 12:59 PM
TexasCTD's Avatar
Chris
http://dodgeram.info/tsb/2005/19-008-05.htm
Old Sep 10, 2007 | 01:14 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Thanks for the backup CTD. Not as saavy on these computers as most.
Old Sep 10, 2007 | 01:22 PM
TexasCTD's Avatar
N E time Bro!
Old Sep 10, 2007 | 01:26 PM
SSminnow's Avatar
Originally Posted by TexasCTD
AH HA! COOL.
Old Sep 10, 2007 | 11:14 PM
labreck's Avatar
We all have bad days. It was a day for me to. I need to get a vacum pump so i can bleed proprly, driving it is the lazy way to bleed out air but the lazy way is never the wright way. And as far as my spelling, I have like some others, have a tuff time typing and i dont write (spell) to often i do need to get better. Ill try, wish me luck
By the way it does not make noize now, ALL THE AIR IS OUT
tony99
Apr 9, 2014 08:25 AM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
RAK GUY
Apr 5, 2003 10:28 PM
Garz
Nov 17, 2002 02:02 PM
