Possible oil leak?
Old Sep 19, 2008 | 11:35 PM
Dodge man's Avatar
Possible oil leak?
I was driving my 2006 3500 around and when I came home parked it in the garage and in the morning there was this fluid on the floor so I wiped it up and left. Got back home from a run onto town and parked it in the garage again and about 1 hour after I shut it off there was the fluid again. So I put a piece of paper under the truck ran the truck for a minute and waited. the fluid is clear and oily feeling but has no smell and it's falling/dripping right by the torque converter and drips about 2 teaspoons of it and then stops, any of you know what it might be?
Old Sep 20, 2008 | 12:09 AM
hivoltage's Avatar
Sounds like brake fluid...?
Old Sep 20, 2008 | 12:51 AM
BigIron70's Avatar
Cummins Guru
On 06 could be coolant from hose located just behind turbo. Check coolant bottle if low on coolant. Hose clamps are loose, just tighten down and your good to go.
Old Sep 20, 2008 | 07:59 AM
PRO-NRA's Avatar
I have a faint leak as well right on the bottom of the bellhousing but not enough to drip. BTW, how big of a garage do you have to fit your truck? My garage is a few feet short.
Old Sep 20, 2008 | 11:30 PM
Dodge man's Avatar
Thanks for the help. I didn't get to it today yet but I bet your right after doing some more reading.
Old Sep 20, 2008 | 11:32 PM
Dodge man's Avatar
It's 26x24
Old Sep 20, 2008 | 11:50 PM
PRO-NRA's Avatar
Wow that a huge garage.
4320Diesel
Apr 25, 2011 09:50 PM
CACalomino
May 7, 2009 04:56 PM
artieb
Dec 13, 2006 04:28 PM
Southern Pride
Mar 22, 2006 10:36 PM
505diesel
Apr 6, 2005 10:36 PM
