Possible Injector or something else
Old Apr 18, 2014 | 11:22 PM
routerguy99's Avatar
I started getting a rough idle at start-up, sounds like it's missing. After about 1 mile or so it would clear up. or put it in drive,(Automatic)
So I put in an 6oz of Shaffer Diesel Treat 2000 Winter Fuel Additive and a full tank of diesel.
I have used half of the tank, and now it still idles a little rough at start-up (cold) but clears up smooth
I have 152,000 miles on it.
There's is no blow-by and the oil level is perfect. I'm not getting any codes.
Does this mean that the injectors are dirty or is one of the injectors going south?
Do I replace all 6 injectors or just the one that's bad ?
Thanks
Chris
Old Apr 19, 2014 | 10:31 AM
FastTaco's Avatar
With that many miles I think most will tell you to replace them all if one goes out.
Old Apr 21, 2014 | 09:11 AM
soulezoo's Avatar
DTR 1st Sergeant
yes, it's a good bet that one or more injectors is starting to behave badly.
Fortunately for you, there are good diesel places in your area for support. Take it in to one and have them check it out.
With the miles on the truck, FastTaco is right... I would replace all and be done with it.
Old Apr 28, 2014 | 02:39 PM
Just got my truck back from the shop.
rough idle and it sounded like it was missing;
They said it was mt battery Ground wire.
seems to run good since I got it back. Glad it was not an injector.
Chris
Old May 2, 2014 | 11:49 PM
w.tx iceman's Avatar
Chris
Did you get any clatter with this?
Sounds like I may need to check this on mine.
Old May 4, 2014 | 09:24 PM
Deezil's Avatar
Got any video?
Sent from my iPhone using Tapatalk
Old May 11, 2014 | 12:50 AM
estaca's Avatar
true about replacing all 6 injectors , also I had a question answered ,normal start time on the 2003 5.9 is 3 to 5 seconds
as it takes that long to build up the pressure to start i hope this helps .i also noticed tonight i went out to start the truck , i gave it a little peddle started real fast lol any real facts on running the k&n air filter ?
ram4tow
Dec 7, 2009 06:51 PM
DarkCat
Nov 27, 2005 03:21 PM
Dorkweed
Mar 27, 2005 11:10 AM
steele37031
Dec 1, 2004 05:57 AM
Puke
May 22, 2003 12:18 AM
