PO338 Code
Old Oct 31, 2011 | 11:44 AM
gcasper1973's Avatar
PO338 Code
I have a 2005 Ram 3500 with a PO338 error code. I have replaced crank sensor and can't seem to clear that code. Anyone have this problem before? or what may need to be done to correct problem as I may have not fixed the problem. I am not sure what to do next. Thanks!
Old Oct 31, 2011 | 09:22 PM
horsehelper's Avatar
I had this problem and chased the wiring under the oilfilter were it can rub. This was bad but didnt help my code. What I had going on was my bolts in my harmonic balancer were coming out and throwing everything off. Once I got this all fixed the truck has been running great. Hope this helps
Old Oct 31, 2011 | 09:31 PM
madhat's Avatar
Administrator/Jarhead
05... First, I'd load check the batteries.
Then...
Possible causes:
(K6) 5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
INTERMITTENT CONDITION
ECM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
bkay
Mar 25, 2003 10:41 AM
