pilot injection
Old Dec 9, 2003 | 05:19 PM
mitchkim's Avatar
pilot injection
does the pilot injection turn off when these trucks are cold
when i crank mine up when its below 45 degrees it is really loud through first and second gears then it quitens down
at idle its quite its only loud when i press the throttle
is this normal ???
Old Dec 10, 2003 | 01:38 AM
Vaughn MacKenzie's Avatar
Re:pilot injection
Mine does the same, they all do. When they're bone cold I don't think the initial pilot burst of fuel lights off at first, only when the bigger shot hits, and when it does light there is more fuel in the cylinder causing a louder clatter.
Sooo, in closing, they're not quite as quiet in the morning 'til they quit the kwatter :
Vaughn
Old Dec 12, 2003 | 08:50 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:pilot injection
Actually your pilot injection is quite likely turned off. During testing on the scope, its been found by a variety of sources that the pilot injection will often turn itself off when under certain load conditions. I'm not sure about temperature sensors, however the additional load of a cold engine may be enough to turn off the pilot injection until you get up a couple gears. Most of the 03/04 trucks that I've been around will exihibit this tendency.
Rod
Remnik
Nov 24, 2006 08:13 AM
Graphite600
Apr 11, 2005 09:29 PM
db
Feb 2, 2004 08:38 PM
Jerry R
Dec 24, 2003 03:07 PM
B1 Power Wagon
Jun 23, 2003 02:14 PM
