P2509 code
Old Sep 4, 2009 | 07:56 AM
wafflehouse's Avatar
P2509 code
I'm getting a p2509 - ECM/pcm power input signal intermittent code. What does that mean? Is the power supply to my computer messed up? Trucks not running bad.
Old Sep 6, 2009 | 07:17 PM
fordassassin's Avatar
Usually passenger side battery is running low.
Old Sep 7, 2009 | 11:45 AM
hector's Avatar
Got that same code this am. Cleared the code. We'll see if it returns... Also,,, had a p1740 code at the same time ... anyone know if the 2 are related ??? Only had this truck for about 3 weeks.. Now this...I stayed away from new because of all the codes.. only to get a 5.9 with codes
Old Sep 7, 2009 | 01:35 PM
w4phj's Avatar
Mine displayed P2509. Dealership replaced driver's side battery. Problem gone now for 2 months.
Old Sep 7, 2009 | 03:11 PM
hector's Avatar
any idea what P1740 is ??.......Ok,, found out what the code is.... TCC Solenoid or overdrive solenoid performance>>>>>>what ever that means ????
Old Sep 8, 2009 | 04:14 PM
thanks guys. I think that solved it.
Old Sep 8, 2009 | 09:48 PM
Rednecktastic's Avatar
If you need new batteries the truck will do weird stuff. Try getting your batteries load tested and get new ones if needed then delete the codes.
I'd try that first before worrying too much.
Old Sep 15, 2009 | 05:42 AM
BLACKBEAR's Avatar
It is best to replace both BATT at the same time.If the old one needs more charging it will over charge the new one.
Old Sep 15, 2009 | 12:15 PM
texasaggie2005's Avatar
https://www.dieseltruckresource.com/....html?t=248741
This was my experience with P2509. Turned out to be a loose ground on my batteries.
Old Jul 16, 2021 | 08:25 PM
GASKICKER's Avatar
Ive replaced batteries 3 times over the years on my truck and never gotten p2509 code before they went out.
JARHEAD
Mar 5, 2020 01:08 AM
ROOSTER108BM
May 27, 2007 11:39 AM
Nuttymopar
Apr 26, 2005 08:16 AM
kertoncol
Jan 19, 2004 10:18 AM
