P0500 vss code on a 2006 2500 5.9 Maga Cab
Old Jul 9, 2013 | 01:23 PM
Team 307 Mafia's Avatar
Ok this is kickin my but! One how does this code come up as a pcm code when its a abs? ABS,Brake and the engine light are on and no speedo. Anyway I have been doing a lot of reading on this and have done what everyone else has tried but I dont seem to be having any luck. I have changed the sensor on the diff and the pig tale Fallowed the wiring all the way up to the ABS ecm changed the sensor on the tranny re programed everything three times just to make sure. Don't know what to look for next. O yeah and my 4 wheel drive just blinks and wont go in. I didnt know if this could be a vac problem?? or wth
Old Jul 9, 2013 | 11:59 PM
ok so I found out it does have 4 wheel ABS, I pulled the tires off and pulled the front sensors out Driver side looks good and passenger side had some chunks of stuff I thought it was some metal but it was more like dirt build up and it has a small ding not sure if this will cause the abs and brake light to come on but after taking it out and when I went in to clear the code it comes right back on now. any help on this would be great
Old Apr 9, 2014 | 05:20 PM
bullrambler's Avatar
It could be your ABS sensor. You may need to change it out. Was it at the wheel bearing or at the upper end...?
slow2run
34
Oct 28, 2010 09:43 PM
loco one
Nov 22, 2007 05:08 AM
rig welder
Jul 29, 2007 09:41 PM
figure_9_pro
Dec 5, 2004 08:29 AM
More Power
Jan 20, 2004 10:58 AM
