one piece aluminum driveshaft
Old Jan 2, 2009 | 03:27 PM
diezel11's Avatar
Talking one piece aluminum driveshaft
just installed a one piece aluminum driveshaft that i got from my local dealer dodge makes one for every truck
just takes a little prodding to get parts guy to find the part number
lists for 425 for my rig
05 dodge quad cab long bed dually
Old Jan 2, 2009 | 07:26 PM
2006BLKMegacab's Avatar
What kind of power is it rated to handle before it looks like a pretzel?
Old Jan 2, 2009 | 07:57 PM
rich's Avatar
yea i can twist a steel one wonder what i could do to an aluminum one
Old Jan 2, 2009 | 09:19 PM
diezel11's Avatar
was designed to replace two piece i would assume it would be stronger
check it out it the same as the ones on new dodges
Old Jan 3, 2009 | 12:56 PM
kertoncol's Avatar
Still trying to find a 2008 so I can see if it will fit on a 2003 to replace my 2-piece.
Old Jan 3, 2009 | 03:05 PM
trik396's Avatar
Usually an aluminum driveshaft will be of a thicker material. I had one built for my Chevelle a few years back. It was a 3" tube with .125" wall thickness and was rated at 1000hp.
Old Jan 9, 2009 | 09:13 PM
ya but there is a big difference in the size of driveline components built to handle horse power than stuff built to withstand torque, I know my Kenworth has bigger driveshafts than any dodge and its only 550 horse but 1850 Ft Lbs, torque will destroy alot more stuff then horsepower ever could
Old Jan 9, 2009 | 09:49 PM
13FOX's Avatar
Funny you mention that. My 08' has a steel one piece (yes I know its a reg cab.) but wonder why steel????
Old Jan 9, 2009 | 10:03 PM
I think steel is the common material for drive shafts because any welder with a bit of experiance can build them, not everone can weld aluminum. I might be wrong but thats my theory
Old Jan 10, 2009 | 08:40 AM
trik396's Avatar
I understand that entirely. Plus the fact that that torque is used to push MUCH higher weights... BUT,
they just use thicker walled tubing... ie.. .250 or .375" wall thickness. Pretty darn strong stuff.
Old Jan 10, 2009 | 06:09 PM
05doolie's Avatar
Do you have the part#? I have the same truck. Does it stop the takeoff stutter?
Old Jan 11, 2009 | 06:20 AM
Topper's Avatar
What is the benefit in going to a 1 piece? What difference did you notice Diezel 11?
Topper
Old Jan 12, 2009 | 12:34 PM
TX_Diesel's Avatar
I'm curious to know the benefit as well, if any??
Old Jan 12, 2009 | 01:42 PM
spider_1954's Avatar
Topper
The one piece will cure the shutter on take off. If you don't have that problem then you don't need to replace it.
Also if the truck is under warranty then Dodge will replace it free of charge if you complain about the shutter.
Old Jan 12, 2009 | 03:39 PM
Seabiscuit's Avatar
quad cab, shortbed ?
Question, Is the aluminum driveshaft available for a quadcab-shortbed truck?
