Ok need a little advice on tire size.
Old Feb 2, 2010 | 09:33 PM
Danderson's Avatar
Originally Posted by Mark03Ram
Ok running toyo 285/75/17 now about time for new tires. Pretty sure I am going to go with the Nitto Dura's this time. I like the 285/75 size but my problem is I tow alot around town. I am wondering if I go with the 285/70 if the smaller diameter will help improve my MPG, anyone made this comparison?? What about the difference in High way MPG, got the auto trans.
Ok so ideas on size, I really dont know how much difference it will make. That is why I am trying to see if anyone else has played with it before. Thanks guys.
I did take a hit power and mileage wise when I went from the 285-70-17's to the "75's". I carry 2000# on my back constantly. With the low final drive on my g-56 I've got the equivalent of 4.11's. The "75's" dropped the rpms but nailed me performance and mileage wise slightly. I think you'll do better with the "70's". They don't look as cool but are more funtional when hauling or carrying heavy loads.
Old Feb 3, 2010 | 02:16 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
i had no mileage change between 285/75R17's and 285/70R17 both AT's
I have the nitto teras and i think next time i am buying two sets a set of duras for most of the year and a good set of AT's or something aggressive for the winter muddy adn snowy months
2.5 mpg sacrificed for running MT's and 1.5 mpg with the taller 315/70R17's in an AT
I tow a 16k lbs gn regularly and with my nv5600, 3.73's and the 285/75 R17's rpms and cruising numbers are perfect. my 315's were too fast in OD leaving me hunting between OD and direct on mild grades. my 285/70's were nice but the slight step up to the 285/75s really got me where i wanted to be rpm, size, fit, and capacity wise. in CA with the 55 mph speed limit while towing i can cruise 60 mph and everything is smooth yet when i head to montana and i am doing 70-75+ i still have the rpms in a smooth range and not wound out
Old Feb 4, 2010 | 08:46 PM
BG05TD's Avatar
Originally Posted by TexasCTD
I think you are right about the height on the 285/75s. They are slightly less diameter than the 35's.....but thinner and lighter.
I don't notice any tire rub with my current tires. I had a little with the 35'' muds, but even it wasn't an issue.
Nice. My plans are to Level...then get some meat under it! Thanks for the info
oldwhite12v
Mar 25, 2011 04:28 PM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
ValkSmile
Jan 23, 2007 11:42 AM
ShawnQ
14
Aug 3, 2006 05:40 PM
