Oil pressure where?
Old Dec 26, 2007 | 12:32 PM
fredbert's Avatar
Oil pressure where?
I think I'm going to install a real oil pressure gauge in my truck. Where does the stock glorified pressure switch look at pressure, before or after the filter? It probably doesn't make a big difference, but I would rather compare apples to apples. Thanks, guys!
Old Dec 26, 2007 | 12:48 PM
Rpainter's Avatar
i used the port on top of the oil filter housing
Old Dec 29, 2007 | 11:51 AM
fredbert's Avatar
Thanks, but that's not quite what I was asking. Anyone else?
Old Dec 29, 2007 | 12:56 PM
Rpainter's Avatar
there is no way to compare the factory gauge gets a signal from the ecm to show what the pressure should be at that engine temp and load on the motor.The sensor giving the ecm the signal will read 7 psi of pressure and your gauge will show 40 psi. anything below that is when the cel will come on
Old Dec 29, 2007 | 11:27 PM
bgott's Avatar
I believe it's after the filter.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
