Oil pressure
Oil pressure
I have an 05 Dodge 2500 4x4 with 2000 miles. I noticed while pulling the other day that when I let off the pedal that the oil pressure dropped down to the "lowest part of the white bracket" or 20 as far as I can tell on a stock gauge.
Is this normal? What is ok?
The gauge in the dash is not real. It is an idiot gauge. You'll need to hook up a real oil pressure gauge if you want to know what it is operating at.
I recall that the DRB scan tool doesn't even provide an oil pressure value for my friends 04.5 600. In fact the new version of software has about half the information as the version for the 98.5-02 trucks has.
Originally Posted by nickleinonen
true. as there is no pressure sensor in the lube oil system. only a 6psi switch.
Pretty silly on Cummins part since they specify that the minimum operating oil pressure at idle is 25psi. By the time you are at 6psi it's almost too late.
Originally Posted by factory service manual
Engine Oil Pressure (MIN)
At Idle 68.9 kPa (10 psi)
At 2500 rpm 206.9 kPa (30 psi)
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
