Oil Pressure
Oil Pressure
Anyone have HOT oil pressure observations?
So, I took the boat to the lake yesterday to check everything out, before we leave on Saturday, and was horsing the boat up the hill.
Not a huge grade, probably 4-5% for ~2-3 miles. 45-55mph, 3rd locked out and turning ~2400 rpm.
Temps:
Ambient 92F
Water 200-210
Trans 175-180
Pyro 800-1000
Oil Pressure (at~2400rpm) >60psi
Now the biggie: At idle after the hill, the oil pressure was ~12psi. Once I got back into the city and driving around, oil pressure cam back up to it's normal hot ~16-18psi. i.e. the oil cooled down.
I am running Valvoline 15W40 w/ a stratopore filter and was changed about 1k ago.
I recall reading in the DC manual that anything over 10psi at idle and over 30 psi at 2500rpm is acceptable.
I am assuming this is normal oi thinning due to temperature.
Anyone else see this?
TIA
Tony
Temps:
Ambient 92F
Water 200-210
Trans 175-180
Pyro 800-1000
TIA
Tony
I'm using a Autometer Phantom mechanical gauge and even after a fairly hard run I see 20-22 psi. The truck has 14K on it.
Cold (45-50F), I see 90 psi at cruise (1000 rpm), dropping to 65-70 psi at operating temperature at cruise.
Dale
Dale
GlennRMK
May 24, 2007 10:46 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
