oil pan leak question 2003 Ram 2500 Diesel 4x4
Hi all. I'm having oil leak from the front of the oil pan. it looks to be coming from around the bolts. I tightened the bolts a little. But I'm wondering if there is a way to replace the seal. Can the pan be removed from under the truck easily. And put a new gasket on? Thanks
Cummins Guru
Could also be rear crank seal or front crank seal. Sloppy oil change or loose oil filter. Check oil fill level make sure oil level is not over full mark. If over full mark could have injector issue.
So if oil is leaking around the bolts, is there a seal to replace? If there is an oil pan seal can the pan be removed from under the truck easily for replacement? Thanks, I do not have a service manual for reference.
Try and look up through the auto tranny inspection plate with a flash light to try and get an idea if its the main seal. Had mine replaced. Leaked a little then got worse. One day parked on an incline started to get a small puddle.
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
