oil pan hole
Old Jun 7, 2014 | 02:31 AM
bill moore's Avatar
oil pan hole
04.5 ext cab 4x4 200 000 kms Just bought this truck go to change the oil notice rust on the pan. start picking at it as I am going to oil spray ot this week and BOOM a **** hole! I need the truck. JB weld or should I tig a 2 x 2 patch on it?
Old Jun 7, 2014 | 09:41 AM
.boB's Avatar
Pull the pan off, clean really well, and weld a patch on. If you have the time, I'd replace it.
Old Jun 7, 2014 | 12:04 PM
bill moore's Avatar
That is the problem got no time. If I pull the pan off I will just change it. Going to try Jb Weld on it. Will post results. Hope to buy myself a couple weeks out of it.
Old Jun 7, 2014 | 05:08 PM
Danderson's Avatar
A guy posted a source on E-Bay for $299. I've fixed mine twice now. I'm five miles from the ocean.
Old Jun 11, 2014 | 12:34 AM
Bark's Avatar
Its amazing how many people have had oil pans rust out.
It just doesn't seem possible that an oil pan could rust through but I keep sanding mine off and spraying it with paint every oil change and it still keeps getting rusty.
Old Jun 11, 2014 | 09:30 AM
Danderson's Avatar
My '98.5 never did it. Same location.
Old Jun 13, 2014 | 07:28 PM
bill moore's Avatar
Most of the pan is still in great shape. Must have been some mud on one side that caused ot to rot out like it has. Tipped the truck to one side to stop the oil from bleeding out. Ground all the loose rust off. Put some kwik jb weld where the hole was waited for that to set. Then a good coat of the original jb weld all around. Good so far
Old May 18, 2015 | 05:14 AM
Dynocon's Avatar
I have a write up on here about changing mine. When I pulled it off the inside was fine but I had several spots that were bubbling under the paint, looked like a little rust was on there before they painted??
I had JB weld on for several weeks before I rounded up the pan and gasket, you can fix that spot but there are move after that, if it starts leaking while driving down the road will the light go off before you do permanent damage?
Search for the write up if you decide to change it, will save you some time.
Old May 18, 2015 | 09:08 PM
StealthDiesel's Avatar
Originally Posted by Dynocon
.... if it starts leaking while driving down the road will the light go off before you do permanent damage?
NO... No one should drive their truck around with a temporarily fixed oil pan, unless you have time and money to waste...
Old May 26, 2015 | 03:46 PM
trik396's Avatar
i have had mine jb welded for a long time now and have no other issues and i check it every oil change obviously.
Mopar1973
Jul 29, 2012 01:47 AM
ofcmarc
Sep 12, 2008 11:56 PM
Mechanos
19
Jan 31, 2006 10:08 PM
JohnnyH
May 11, 2004 10:14 AM
