oil level high?
Old Feb 2, 2005 | 08:28 AM
Graphite600's Avatar
oil level high?
My didpstick reads right on the edge of the full mark (the full side of the safe zone) is this alright, will it hurt anything, I checked it this morning after it sat all night.
Old Feb 2, 2005 | 08:37 AM
ed paul's Avatar
same thing happen to me when i changed oil the first time, oil level went right to the top of the saftey zone, the next time i changed it, i held back a quart it . that got me to the bottom of the saftey zone,,so i added 1/2 quart and i was good,,right there in the middle.
I"m sure it isn"t going to hurt anything being at the top of it.
Old Feb 2, 2005 | 10:27 AM
Lightman's Avatar
As EdPaul has found - if you just dump 3 whole gallons in you will be slightly overfilled. The capacity is 3 gals, and you never get 100% out when you drain.. In any case, you will be fine as long as it's close/not too far over, and next time try adding 11.5 or 11.8 qts...
Old Feb 2, 2005 | 11:07 AM
bigblock2stroke's Avatar
the distance between the low and full marks on your dipstick is actually 2 quarts.
Do not over fill. You might fug up your crankcase ventilation system and you will have added drag to the crankshaft when it swings through the sump.
You should have it at the top of the full lline, but not past it. Running it halfway inbetween (1 quart low) is also fine.
Old Feb 2, 2005 | 05:06 PM
thames1948's Avatar
When I change oil, 3 gallons doesn't take mine to the top of full but
still above safe mark
Old Feb 2, 2005 | 05:50 PM
Hounddog's Avatar
A little over or below dosen't bother a thing.Put three gallons in it and drive.
Old Feb 3, 2005 | 08:01 AM
Neil58's Avatar
11 quarts per the service manual. owners manual, service manual and I all advise you not to overfill your crank case. This always puts me right into the safe zone.
Old Feb 3, 2005 | 09:25 AM
nickleinonen's Avatar
i use 3 gallons in mine... fill the filter up, and dump the rest in...
Old Feb 3, 2005 | 01:14 PM
Hounddog's Avatar
12 qts includes filter.Were did 11 come from?
Old Feb 3, 2005 | 04:47 PM
Welder's Avatar
My "2004 Ram Truck Diesel Owner's Manual" Page 378 fluid capacities reads U.S. 12.0 qts
Metric 11.4L. 3 Gals thats what I always put in. Brings it to the top of the safe zone.I like buying a case and having enough, with my old psd I bought a case and was a 1/2 gal short
Old Feb 3, 2005 | 05:23 PM
bulabula's Avatar
3 gallons; never made a difference if the gallon jugs were from Mobil, Rotella or Amsoil.
Old Feb 3, 2005 | 11:00 PM
Neil58's Avatar
I stand corrected....12 Quarts/3Gallons......must of been in metric mode on my first post. Sorry.
Old Feb 4, 2005 | 11:26 AM
Lightman's Avatar
It's just not possible to get every bit of oil out - so three gallons typically overfills just slightly every time I've tried it. 11.5 quarts or so does just fine. You don't need to be all the way up to the max line - it's not like this is a 4 quart system and you really need to have all you can in there...
Old Feb 4, 2005 | 07:07 PM
Hounddog's Avatar
I drain/put on new filter,dump in three gallons and its good to go.And NO I don't prefill my filter.
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
