Oil filter leaking?
Old Feb 5, 2005 | 01:57 AM
Jmac's Avatar
Oil filter leaking?
Hello All,
I noticed the other day while under my truck that my oil filter is leaking oil. I wiped off the little bit I found on the bottom of the filter and loosened and retightened the filter 1 full turn from point of contact... It's still seeping, just enough to show a drip of fresh oil at the middle of the bottom of the filter. I think I've got a bad filter.
BTW I use the Fleetguard Stratapore filter.
Any thoughts?
Jamie
Old Feb 5, 2005 | 04:34 AM
papaduck's Avatar
Did you make sure that the old gasket came off with the old filter?
Old Feb 5, 2005 | 05:28 AM
Dodgezilla's Avatar
Put a new filter on it.
Old Feb 5, 2005 | 07:14 AM
Geico266's Avatar
I've never had a problem with a leaking filter. I would just replace it (like Dogezilla says) and top off the oil level and check it is a week.
Old Feb 5, 2005 | 12:10 PM
Jmac's Avatar
I will double check the double gasket thing right now. and will get a new filter if no double gasket.
thanks guys.
jamie
Old Feb 5, 2005 | 10:24 PM
gatf4's Avatar
I've seen at least 6 bad filters in the last year at my shop. (Valvoline, rebadged purolator) We do about 400 oil changes a month, so the ratio is pretty small. They leak from the top seam. I've not seen a bad one on a Cummins though . Replace it and recheck it.
Old Feb 6, 2005 | 10:55 PM
Jmac's Avatar
OK... I did not have two rubber gaskets on it, just one. It looked to me to be defective. looking at the rubber gasket from the side, it looked like about a 1 inch section sat deeper into the filter causing a poor seal.
new filter doesn't leak.
Is it OK to tighten a new filter 1 full turn, b/c that's what I've done since I bought the truck new. Or should I just go 3/4 of a turn on like the directions on the filter say to?
thanks for your input,
Jamie
Old Feb 7, 2005 | 04:23 AM
Dodgezilla's Avatar
I always go hand tight then about 1 more turn with the filter wrench. I've never had a problem.......
Old Feb 7, 2005 | 02:12 PM
bluepp's Avatar
The rubber gasket comes right off the filter . Take it off ,if bad gasket ,save filter ,use next time and use the old ,good gasket from filter on there now. Realy I would, but you got to keep filter clean.
Old Feb 7, 2005 | 05:20 PM
moterhead's Avatar
An oil filter leak that is only a tiny drip won't be double gaskets. I had that experience on a Mustang 5.0. When you start the engine and have double gaskets on the filter, you have essentially NO seal. You will almost instantly have many quarts of oil on the shop floor. JOIBO.
Old Feb 7, 2005 | 07:05 PM
Jmac's Avatar
I did look a the gasket briefly and tried to place it back in the grove of the filter. This was hard to do b/c the ring was now about 1/4 too big in circumference. My Cummins parts guy said to bring it in and if he can see that it's defective he'll give me a new one at no charge
Jamie
Old Feb 7, 2005 | 07:45 PM
Geico266's Avatar
All this for a $10 filter? Plus is could leak again? Toss it and get a new one.
roughstock
Jul 31, 2008 10:12 PM
codered
Dec 25, 2005 05:55 PM
horsepoor68
Dec 13, 2005 08:30 PM
marc03
Nov 8, 2005 09:27 AM
Sidewinder
Jul 13, 2004 10:48 PM
