leaking oil filter
Old Dec 13, 2005 | 05:04 PM
horsepoor68's Avatar
leaking oil filter
Had my fourth oil change last nite. I went to leave for work this morning, pudddle under the truck the filter was leaking. I had the oil chnge place use my wix filter. took it back today they removed the filter it was tight. They replaced with one of there own got home leaking again. I got my old filter back the seal was ok and the threads were ok no cross threading. Any help on what could be wrong.
Old Dec 13, 2005 | 05:46 PM
Casey Balvert's Avatar
Put on a Mopar or Fleetguard and if it still leaks, there is definitely a problem. They didn't crack the filter attachment housing did they?
Old Dec 13, 2005 | 05:53 PM
djbikeman's Avatar
Are you sure the old filter seal was removed? They tend to stick when you pull of the old filter.
Just a thought.
Old Dec 13, 2005 | 06:30 PM
as far as i could tell it was. cant be certain. ill take it back tomorrow again and talk to the mannager
Old Dec 13, 2005 | 08:26 PM
eb290's Avatar
When that happens it is usually that the old rubber gasket came off your filter when you changed it and the other was screwed on over it. It will leak every time. You are lucky you didn't start off on a long trip.
Old Dec 13, 2005 | 08:30 PM
GSP's Avatar
GSP
Unbelievable!
roughstock
Jul 31, 2008 10:12 PM
codered
Dec 25, 2005 05:55 PM
marc03
Nov 8, 2005 09:27 AM
Jmac
Feb 7, 2005 07:45 PM
Sidewinder
Jul 13, 2004 10:48 PM
