oil change mess
Old Jul 23, 2004 | 08:27 AM
Altaboy's Avatar
oil change mess
I just did my first oil change (my first not the trucks). How do I aviod the oil running down my sleeve when you remove the filter. Whats the trick or what am I missing.
Thanks
jerry aka:dirty sleeves
Old Jul 23, 2004 | 08:35 AM
rock's Avatar
I wrap a rag around it. That way the rag catches the little bit of oil before it gets to my hand. An old T-shirt works well. Others have a more scientific method.
Old Jul 23, 2004 | 08:36 AM
Buzzer's Avatar
Put a plastic bag over it as you remove it and exercise some caution is one way.
Old Jul 23, 2004 | 11:20 AM
bulabula's Avatar
At first I thought you didn't have a 4x4. Maybe be more careful?? I just lie under mine and reach up and unscrew it - no muss no fuss. I removed mine about 7 times now and have never spilled anything out onto my hand or arm. There might a slight spill over the lip of the can, but nothing to write home about.
Old Jul 23, 2004 | 04:11 PM
mudturtle660's Avatar
i trimmed my inner fender a bit so that i can take it off from the side
Old Jul 23, 2004 | 04:14 PM
thames1948's Avatar
I change mine from the top and also put a plastic around it and no spills yet.
Old Jul 23, 2004 | 05:54 PM
45auto's Avatar
Freezer bag, from the bottom and unscrew
Old Jul 25, 2004 | 11:37 AM
DodePops's Avatar
Mine's a 2003 4x4 and it don't spill any oil for some reason, maybe because I let it drain for a hour or so? But a friend of mine has a Ford and it uses a huge filter, he don't lke handling the weight of it filled with oil so he puches a hole it the bottom with a screw driver and lets it drain. Another Idea?
Old Jul 25, 2004 | 11:47 AM
1sttruck's Avatar
I unscrew mine from the bottom using the tool from Geno's and so far haven't spilled anything, but I guess I just hexed myself :^)
Old Jul 26, 2004 | 11:15 AM
1sttruck's Avatar
I changed mine yesterday and didn't spill anything while reaching from the bottom and using the tool from Geno's. The tool was slipping though, so I used a hacksaw to slice the wall of the tool in six places, deburred the slots, put a large hose clamp on the tool, and it fit perfectly on the filter where I had to lightly force it on. No more slipping, but I will look for a metal tool for use next time.
Old Jul 26, 2004 | 01:32 PM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
Changed mine yesterday...I have a second oil drain pan that I put underneath the filter while the oil drains from the pan. I unscrew the filter enough to have it start dripping and once it's stopped, I take it off all the way and keep the filter vertical. Still get a bit of oil on the hands, but otherwise it's pretty neat.
Old Jul 26, 2004 | 08:42 PM
SageBrush 1's Avatar
No spills here either. I just keep it vertical and unscrew from below. I'm on my third change and i do not change it "hot", just warm, just incase.
Old Jul 27, 2004 | 06:46 AM
BNC04's Avatar
A trick I learned when changing the oil on my 4.7 Dakota was to cut the bottom off a liter soda bottle, leave the cap on... slip it over filter loosen first) then just use your hand to remove the filter , any drips fall into the bottle. I tried the freezer bag and this is much easier for me.
Brett
jimmyd
Jun 4, 2010 02:10 PM
dodge_kid9712
Jan 10, 2008 05:59 AM
SilverRam3500
Mar 26, 2007 11:12 PM
sacnvr2l8
Jul 16, 2006 04:07 PM
tmiller24
Mar 9, 2003 08:35 AM
