Oil tube in front of engine makes a mess!
Old Mar 26, 2007 | 11:27 AM
SilverRam3500's Avatar
What is the deal with the crankcase oil tube that comes out the front of the engine and down to dirty the entire front end and back. I t makes a mess underbody all the way to the starter.
I thinkmy starter got messed up because of that. I jsut replaced it .
Is there a fix for this tube thing and what is the deal with this tube?
Thks in advance! T
Old Mar 26, 2007 | 11:32 AM
Paintpusher's Avatar
Replace it with a longer tube that goes down to where the front stabilizer meets the frame on the drivers side. You can either tuck it in there or wire tie it on. It should just blow it on the ground and not all over everything else.
Old Mar 26, 2007 | 10:03 PM
davemac's Avatar
You might also want to check your radiator. The gunk from the tube can get between the fins and cause overheating problems.
Old Mar 26, 2007 | 10:56 PM
BCSCUMMINS's Avatar
Just drain the canister when you change the oil it just unthreads from the hose.
Old Mar 26, 2007 | 11:12 PM
DL1221's Avatar
It sure does, it makes a freaking mess on the radiator!
I took my radiator out last summer, and I can't believe how much gunk was between the fins. I used five cans of degreaser at the car wash to power wash all that crud out. I relocated the puke bottle to below the fender away from the fan and the engine, truck is clean as whistle now, and runs cool as a cucumber.
The Cummins engineer responsible for the puke bottle should get fired, along with the guy who designed the lift pump!
IPDiesel
Dec 29, 2010 09:21 AM
azmusclecar
31
Mar 31, 2008 11:53 PM
Dean Snow
Sep 21, 2007 01:18 PM
tmiller24
Mar 9, 2003 08:35 AM
