nv5600 reverse lights
Old Jan 22, 2007 | 01:47 PM
reb0957's Avatar
Is there anything besides the reverse light sensor that would cause the reverse lights to only work intermittently? The dealer won't fix under warranty because he says it doesn't do it in his shop.
Any help before I spend $80 on the part would be helpful!
It wouldn't bug me so much if I hadn't almost got hit 2 times because of no reverse lights.
Old Jan 22, 2007 | 02:16 PM
goodeyesniper75's Avatar
mine didnt work because the trans sensor on the passenger side of the trans had come out and when i put it back in they worked....
Old Jan 22, 2007 | 02:19 PM
reb0957's Avatar
It is in there. it is just intermittent.
Old Jan 22, 2007 | 03:40 PM
nsxt's Avatar
The reverse lamp switch is notorious for going bad. Replacing takes is about 5 minutes and $40 from Autozone.
To test if it is the switch gone bad and the rest of the circuit good:
Take the connector apart at the transmission.
Jump the harness pins with a paper clip.
Reverse lights should be on solid.
Obviously, regardless of transmission gear.
Or, you can test the switch with an ohmmeter and somebody else wiggling the shift lever.
Old Jan 22, 2007 | 03:58 PM
RustyJC's Avatar
Mine was intermittent for a good while before the switch failed completely. Changing it out was less than a 5 minute job.
Rusty
Old Jan 23, 2007 | 09:01 AM
mattk50's Avatar
Mine were working intermittantly as well.Got a new b/u light switch from the ******* and replaced it saturday.5 minutes work and $62.00 plus tax for the part.Its made by pollack so should be available elsewhere cheaper.
tntshrekuk
Jun 25, 2008 12:02 PM
reb0957
Jan 17, 2007 10:07 AM
05mxdiesel
17
Aug 15, 2005 06:01 PM
Jdonoghue
Jul 6, 2005 10:07 AM
stonewalldiesel
Aug 26, 2004 11:16 AM
