NV5600 noise
Old Nov 26, 2007 | 03:58 PM
98xc800's Avatar
NV5600 noise
My NV5600 is making a growling noise in 6th and 4th gear only. Are these gears on a common shaft?
The noise just started about 1000 miles ago.
I am driving it in 5th(dead quiet) on the highway now. The nearest real transmission shop is 600 miles away, so I will have to limp it there to get checked out.
Old Nov 26, 2007 | 03:59 PM
MikeyB's Avatar
When was the last time the fluid was changed, or even checked?
MikeyB
Old Nov 26, 2007 | 04:05 PM
Secondrate's Avatar
are you lugging it when the noise comes and yes check fluid cause that thing get really hot i change mine every 15000
Old Nov 26, 2007 | 04:48 PM
rip 112's Avatar
Throwout may be on the way out. Check your fluid.
Old Nov 27, 2007 | 02:11 AM
Kman9090's Avatar
Mine kinda makes a howling noise in every gear when you lug it kinda like you can hear gears moving but every nv5600 and nv4500 i've been around has done it.
Old Nov 27, 2007 | 10:38 AM
rip 112's Avatar
Mine makes a similar noise, but only in the lower gears. The nv5600 is a noisy manual, alot of low rpm rattling, whining occaisionally...
Old Nov 27, 2007 | 11:34 AM
MikeyB's Avatar
Mine is pretty quiet except for the low rpm gear rattle, but I have 6 quarts of Amsoil MTF in there.
MikeyB
Old Nov 27, 2007 | 01:31 PM
rip 112's Avatar
Yeah, I've been due a fluid change, but got to scrounge up the $$$ first. With diesel prices the way they are I can barely afford to fill my truck up full.
Old Nov 27, 2007 | 01:42 PM
Spooler's Avatar
You might want to check the fluid level anyway. A quart or two of fluid is alot cheaper than a burned up NV5600 repair.
Old Nov 27, 2007 | 02:56 PM
98xc800's Avatar
I run 1 litre over full all the time. I have been using the Mopar synthetic fluid.
Smkn600CTD
May 22, 2012 07:21 PM
mudwisr2
Jan 14, 2010 10:27 PM
chrigu
20
May 9, 2008 11:07 AM
ShowMe06
27
Jan 4, 2008 11:47 AM
Pike
Jun 16, 2005 08:22 AM
