NV5600 and high idle
Yes on the ground pin 22. I added enough wire to the pigtail so that I could ground it inside next to the steering column in case I ever wanted to install the clutch cut-out switch.. The pigtail is Cummins part # 3164263 they are about 1/2 the price(13-15$) of the dodge units..
Try Genos Garage as well..
Cummins part # 4089851 Clutch switch kit
Dodge P/N 05026273AB. This switch is also called the "Switch - Clutch Interlock / Upstop"
It is my understanding this setup comes with the ECM pigtail as well..You might want to double check that prior to ordering
Thank you for the part numbers. I read somewhere that the switch is about half price thru cummins vs. going thru dodge. I know the switch is still more expensive than the pigtail but i feel safety is always a factor. I will have to see if MHC Kenworth has it in stock.
ez
ez
The clutch switch will disengage the hi idle just like hitting the brake pedal does.. It is just another safety feature. Some dealerships won't hookup the hi idle without it.. By installing the jumper yourself you take the liability monkey off there backs.
I am just gonna get a pigtail and ground pin 22. My truck is a 04.5 with a 6 speed, was curious if i got a smarty jr can i enable the high idle with it? or am i still gonna have to go to the dealer. thanks
ez
ez
mj007
24
Dec 7, 2010 07:45 PM
jmccart
Jun 12, 2007 02:12 PM
