Number 6 cylinder gone?
Old Jul 22, 2012 | 08:57 AM
grayzone's Avatar
2005 ram 2500 with 115xxx miles, on initial start up truck blows white smoke, random ticking that starts and stops, rough idle, number 6 cylinder cold on exhaust side, valve cover taken off and all valves are working, unplugged number 6 injector and there was no difference, unplugged number 5 injector and it skipped more. we're thinking next option is compression test. any thoughts out there would be greatly appreciated, thanks.
Old Jul 22, 2012 | 09:50 AM
Hintonc393's Avatar
Best case, just the number six injector.
Worst case, melted piston, injector.
Need to check the oil for fuel, may not smell like it much. Having it tested is the only sure fire way to know.
Old Jul 22, 2012 | 09:51 AM
Hintonc393's Avatar
As you said, compression test is the next step.
Old Jul 22, 2012 | 11:12 AM
grayzone's Avatar
i forgot to add the extensive amount of oil going out the blow by tube. thank you very much.
Old Jul 22, 2012 | 11:13 AM
Hintonc393's Avatar
It's toast
Old Jul 22, 2012 | 11:16 AM
Hintonc393's Avatar
Any warning signs that this was coming? Or did it just blow up?
Old Jul 22, 2012 | 11:50 PM
Spooler's Avatar
Check for codes, no codes, you have a broken ring on #6.
Old Jul 23, 2012 | 05:01 AM
grayzone's Avatar
im not sure what happened just went and shakes the truck at idle, smokes to beat the bad. but we re going to do a compression test if i can find one. thanks guys this is very helpfull!
Old Aug 25, 2012 | 07:49 AM
grayzone's Avatar
well we found out that it was a broke ring on the six piston didnt do any damage to wall or piston rings next on all six thanks for they help guys
Old Aug 25, 2012 | 09:50 PM
rockcrawler304's Avatar
Good thing it was not a melted piston!
Much easier and cheaper fix to do rings.
Old Aug 28, 2012 | 12:59 PM
bradler's Avatar
hmm another 05' with a broken ring....makes me nervous how many ring issues i've heard about...almost to the point of just wanting to put new rings in mine as preventative maintenance!
arroyojim
48
Sep 9, 2016 09:43 AM
cbrahs
Nov 1, 2011 11:00 AM
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
3500Dooly
23
Jun 8, 2006 10:21 PM
