No start missing relay identafication
Old Jul 13, 2008 | 02:03 PM
raybob_99's Avatar
There is a relay that is right above the brake master cylinder, has 2 wires one goes behind the fule filter housing and one goes under the cab. Purchased this truck as a theft, cant get lift pump to prime up. Is that what this relay is for? Can get pic's if anyone isn't following me. Thanks for help.
Old Jul 13, 2008 | 09:31 PM
BigIron70's Avatar
Cummins Guru
Lift pump gets power from the ECM. If your pump is mounted on fuel filter housing it is most likely bad. New retrofit fuel pumps are available for replacement. If under 100k miles covered under warranty.
Old Jul 13, 2008 | 09:36 PM
raybob_99's Avatar
2004.5
I should have listed what model truck i have, mine is a 2004.5, i don't see a lift pump on filter housing.
Old Jul 13, 2008 | 10:19 PM
kruisecontrol's Avatar
the pump is in the tank , the relay for the lift pump is from the small relays column in the power didtribution ceter underhood its the 4th from top to bottom right column left to fuse # 48
Old Jul 13, 2008 | 11:06 PM
torquefan's Avatar
It sounds to me like this truck originally came with the lift pump on the filter housing, then later it was retrofitted to the in-tank pump. The relay and wiring you see are part of the retrofit.
Old Aug 18, 2008 | 01:31 PM
raybob_99's Avatar
pump
Can i remount a lift pump on the filter housing? Even if it has been retrofitted with an intank pump? I think this is what has happened because mopar doesn't show anywiring for the relay. Let me know. Thanks
hodgepodge
Apr 13, 2007 06:30 AM
forane2001
21
Oct 6, 2006 01:13 PM
torqueman
Mar 24, 2006 05:21 PM
mazeppa
Feb 10, 2004 06:54 PM
