No left turn signal
No left turn signal
The truck in my sig i dont have any turn signal on the drivers side on either of the trailer plugs everyting else works on the left side and right side except the turn signal any idea? fuse is good and there is power at the fuse block changed fuses an still nothing any help would be appericated
thanks
thanks
isnt their seperate fuses for the turn signals under the hood and the trailer tow fuses and relay. check your splice connectors also i have had trouble with mine not making good contact
thanks guys i have fuse is good an i have power at the fuse no power anywhere back how do you remove the fuse box i think maybe the wire is broke where it comes out of the fuse box thats the only thing i can think of
My 03 had the same problem. It was exactly that. I have a wire from the fuse box that was pulled out. Hope you find it.
Thanks to ya'll I have found my problem and fixed it. Some weeks it worked others it didn't. I took the turn signal switch out of the steering column to replace it. I heard someone on hear on another thread mention problems when it rained. With nothing to loose I took the switch appart. Sure enough moister was all over the board. I wiped it down with a rag and put it back together. Presto after a year of fighting this it works every time now. It's been a month and it has never failed. Now how did all the moister get in there when I live in Dallas.
CruisingRam
Sep 14, 2004 04:50 AM
