Left Turn Signal
Old Sep 10, 2004 | 12:51 AM
CanuckCTD's Avatar
Left Turn Signal
Hey Guys,
My left turn signal isn't working properly. When I engage the left turn signal the blinker in the cab and the front blink really fast and the rear signal doesn't blink at all. The right side works normally though. Is this a fuse problem or can somebody else suggest a fix?
TIA
Old Sep 10, 2004 | 01:04 AM
FastSS's Avatar
Our tail light bulbs are dual filiment, your bright is burned out so your bulb doesnt flash... it also doesnt get bright when you put your brakes on
Old Sep 10, 2004 | 04:16 PM
CanuckCTD's Avatar
Thanks, FastSS
Ok, so the blub is burnt out, do I have to take the cover off to access the bulb or is it like a headlight and you can access it from the back?
TIA
Old Sep 10, 2004 | 06:37 PM
gallows55's Avatar
Open the tailgate and the screws are inside the edge. This will remove the tail light assembly, and you can then change the bulbs.
johndeere01
Jul 6, 2009 12:11 PM
colby1979
Oct 30, 2007 08:21 AM
TJE
Oct 11, 2006 05:54 PM
VanWinkel
Apr 20, 2005 07:28 PM
CruisingRam
Sep 14, 2004 04:50 AM
