New Water Pumps leaking at high RPMS
Old Oct 22, 2008 | 09:09 PM
tcr's Avatar
tcr
I've changed out 2 pumps now and I'm getting leaks only after I do some hard runs getting to 130+mph or standing on the throttle like 1/4mile WOT. The RPMs get to 3500+. I've had 2 not leak at all after install, then start leaking after these real hard runs. I didn't go back w/ a factory water pump, they were brand new pumps from 2 diff Oreillys; is that my problem? Or is this a serious sign that I need a coolant bypass/pressure relief kit?
Old Oct 23, 2008 | 09:21 AM
tcr's Avatar
tcr
bump.........
Old Oct 23, 2008 | 09:25 AM
Dwitt0187's Avatar
im gonna say that it is the oreilly's pump you need to put a cummins oem one on it.
edit: where is the coolant coming out of?
danny
Old Oct 23, 2008 | 02:48 PM
tcr's Avatar
tcr
It's leaking from the back of the plate. The groove(the gasket rides in) on these water pumps seem to be very deep. I greased the gaskets and cleaned the mounting surfaces really well. Right now it's not leaking at all, but if I haul **** WOT, I can pop the hood and there will be coolant all aroung the water pump. The dealer wants 200+ for the water pump, but if I have a different issue a factory pump won't help!
Old Oct 23, 2008 | 03:01 PM
zuki_dan's Avatar
It may be the combination of the aftermarket pump and high coolant pressures.
I recently blew my headgasket after getting the head o-ringed. When I took it back apart The coolant pressure blew apart the fiber on the 12valve marine gasket in the coolant passage by the #6 cylinder and I had coolant coming from between the head and block. I also had the rear freeze plug blocked off.
I now have a coolant bypass system I fabbed up and It hasn't blown yet.
I also blew the gasket running Beta 4.2 w/ TST at the dragstrip and the truck was warm on all runs.
Old Oct 23, 2008 | 03:10 PM
tcr's Avatar
tcr
The only difference in these aftermarket pumps is the impeller blade has a ring welded to it, I'm not sure why.
Old Oct 23, 2008 | 03:25 PM
Dwitt0187's Avatar
are you sure it is coming from the water pump and not the radiator cap above the water pump it sounds like it is probably time for a bypass.
danny
Old Oct 23, 2008 | 03:54 PM
tcr's Avatar
tcr
I'm absolutely positive it's coming from the water pump, are these bypasses reasonably priced? I'm going to try a factory pump tomorrow and if it leaks I'm not sure where it will land when I throw it!
wrangler04
40
Aug 1, 2007 01:58 PM
Ilikebikes
Dec 11, 2006 10:13 PM
Teddy Bear
May 1, 2006 08:15 PM
iwannaram
24
Dec 20, 2002 11:56 PM
