New Truck, Sloppy Steering with a point of resistance?
Old May 9, 2009 | 08:54 PM
BamaTJ's Avatar
So I bought an 04 2500 Cummins today with about 90k on it. Good power, good truck just has some sloppy steering and it has a really wierd point of resistance if you turn just slightly to the right. Hard to describe but if you turn it slightly to the right, like 2:00 positon, it has a catch point that you can feel in the wheel. Once you get past that point it is fine and it doesn't do it to the left. Anybody had a similar issue or know some good things to look for as a culprit for sloppy steering in general?
Thanks!
Old May 9, 2009 | 10:38 PM
Catmandoram's Avatar
Ball Joints!!!
Old May 9, 2009 | 10:40 PM
Stupid computer. I wish I could blow it up at times.
It should say Ball Joints!
Old May 10, 2009 | 12:47 PM
BigIron70's Avatar
Cummins Guru
Try disconnecting steering linkage at pitman arm. If binding is still there then problem in steering gear box.
Front End Shimmy On 4x4 Vehicles When Traveling Over Rough Surfaces In The Road
The customer may experience a self sustaining vibration (shimmy) felt in the front end of
the vehicle after striking a bump or pothole.
DIAGNOSIS:
If the customer experiences the above condition perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
(AR) 1 52106909AE Damper, Steering
(AR) 1 05086146AC End Package, Tie Rod Outer
(AR) 1 05086144AC End Package, Tie Rod and Link Outer
(AR) 06505623AA Nut and Washer, Tie Rod
Old May 10, 2009 | 06:00 PM
BamaTJ's Avatar
Looked for play today and couldn't find any in the TRE's or Ball Joints. Thinking it might be the gear box..
Old May 11, 2009 | 08:34 AM
BamaTJ's Avatar
Any other ideas/things to look for? None of the front end look to have any amount of play in it, everything looked nice. Would the PSC brace and a new stabilizer help any?
Old Jun 22, 2009 | 10:22 AM
SmokenRam's Avatar
Frozen u-joint in front axle could be a posibility to??
Old Jun 22, 2009 | 12:44 PM
TexasCTD's Avatar
Thanks!
Mine had a similar problem. It is probably the track bar bolt on the driver side "wallowing" out inside the mount. Get somebody to turn your steering wheel with the truck running.....and crawl under your front to look at it and verify.
Lazarsmith.com sells the "ultimate track bar hardware" kit that will fix it. And you can replace the bushings on your tb too while it's out if needed.
http://www.lazarsmith.com/SSSSS.html
After adding this, my steering is nice and tight and no "popping".
Old Jun 23, 2009 | 10:35 PM
MulesDiesel's Avatar
maybe a dent in your steering stabilzer
Mule Man Willie
17
Feb 28, 2012 11:06 AM
bngcustoms
Jul 17, 2009 04:53 PM
02growler
Apr 5, 2008 04:17 PM
mikeo302
Mar 6, 2006 05:27 PM
I PASS GAS
Dec 5, 2004 11:47 AM
