new tires. What to do?
Old 05-27-2008, 08:55 PM
dodgemaniac's Avatar
Question new tires. What to do?
i got my new 35x12.5x17 toyo open country M/T's put on today and they rub. they are on the stock rims.
they rub on the control arms at close to full lock.
What can i do to make them not rub? all options please
Old 05-27-2008, 08:58 PM
bigdave's Avatar
How close are they to the fenders and front bumper, what do you have for running boards if any?
Old 05-27-2008, 09:04 PM
they are proably 3-4in to the fender and i am tube steps
Old 05-27-2008, 09:07 PM
bigdave's Avatar
How close is it to the fender when you turn?
Old 05-27-2008, 09:10 PM
probly 1-2 in
Old 05-27-2008, 09:13 PM
bigdave's Avatar
You could probably just get some wheel spacers then. Or you could go with new wheels with some offset.
Old 05-27-2008, 09:17 PM
where could i get wheel spacers and what size ?
Old 05-28-2008, 02:20 PM
enafzige's Avatar
May not be what you're looking for, but most people just run them like that, and don't turn all the way...unless, that is, it's necessary, because it doesn't really hurt anything.
You may try wheels with around 5.71" - 6" backspacing to avoid the control arm rub, but you may acquire fender rub.
--Eric
Old 05-28-2008, 03:14 PM
Ram Daddy's Avatar
Yep , the problem is , there`s a fine line between hitting the control arms , and hitting the fenders. I`m using 1/4 in. spacers up front(have been for a few yrs. now) running stock wheels and 37X12.50-17 Goodyear GSAs (H1 factory tires) with no rubbing....with a Superlift 6in susp.lift.
Old 05-28-2008, 03:16 PM
Fisherguy's Avatar
It's pretty much a given from reading on here that 35's will rub on stock wheels.
Options would be levelling kit or different wheels.
I hope to get the 35's with some 08 Hummer wheels, they don't rub but I'd still like to get a levelling kit anyhow.
Old 05-28-2008, 04:40 PM
Ram Daddy's Avatar
35s will rub the control arms even with a leveling kit(or even a 6in. lift kit) when using the stock wheels.
The Hummer wheels are the way to go , if you want to keep it nice and clean.
They look sweet.
Old 05-28-2008, 04:49 PM
thanks for the help.
does anybody know where i might be able to find a set of H2 wheels?
Old 05-28-2008, 04:55 PM
Ram Daddy's Avatar
I check craigslist everyday...
...sometimes even more often
If you have a Hummer dealer anywhere close , they normally have takeoffs that they sell pretty cheap.
If you go the e-bay route , you`ll be paying a ton in shipping , unless you get lucky and find someone close.
Old 05-28-2008, 05:28 PM
jamesbfishin's Avatar
If you do indeed get the H2 wheels (the new style for 08 is nicer looking) be aware that there is some slight modification on the center bore that needs to be done. Do a search, you'll find enough reading to last you hours.
Old 05-28-2008, 06:01 PM
Fisherguy's Avatar
Are you sure? Speaking from experience?
I've been following this kinda thing for a couple years here, I'm pretty sure a leveling kit solves the rub but can't say for absolutely 100% certain.
Quick Reply: new tires. What to do?
