New springs, new ball joints, new shocks...odd feeling
Old Sep 6, 2009 | 02:49 PM
  #61
neversatisfied's Avatar
Can anyone tell me the torque spec.for the stock track bar bolts???
Thanks Steve
Old Sep 6, 2009 | 04:43 PM
  #62
trik396's Avatar
150 ft/lbs
Old Sep 6, 2009 | 09:25 PM
  #63
Thanks.
Checked the track bar, ball joints, tie rod ends, steering shaft, Wheel bearing hubs, axle u-joints,steering brace bearing and upper & lower control arm bushings. Everything appears tight. Readjusted caster from max to factory setting and adjusted toe to 1/16" . Took truck for short ride and it drives much better but low speed clunk is still there. Plan on taking it out for a longer ride in the morning.
Thanks for everyone's help
Steve
Old Sep 6, 2009 | 09:33 PM
  #64
trik396's Avatar
Are you sure your track bar is ok? Mine seemed tight when I got under there and grabbed it but when I took it off the bushings were very bad. Also, lately, I've heard nothing but bad things about Moog. Good luck.
Old Sep 7, 2009 | 12:30 AM
  #65
Hamilton713's Avatar
Check your shocks. I have this same issue and thought the wander was related to my clunk but it looks like it is probably the Moog lower ball joints.
The clunk was traced to my front driver's side shock. I still need to replace them but the Rancho's that were on the truck when I bought it are garbage, so I've been told.
Might be worth checking...The guy that did my front end work unbolted the front shock then drove it and the clunk was gone. Put it back together and its back.
Its an idea, good luck.
Old Sep 9, 2009 | 01:07 PM
  #66
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
https://www.dieseltruckresource.com/...html?p=2572476
You can see my thread followed a similar issue it ended up being the moog ball joints.
Old Sep 9, 2009 | 10:03 PM
  #67
bob4x4's Avatar
Originally Posted by RiverRat2
Yeah I got ya there,,,,,,
It will be interesting to see what results abound when the Carli's to come out in Nov.,,,,, if they are no better I probably will just go back with the OEM's myself??????
I have the Carli uppers and have been very happy...they take a lot of abuse and ask for More.I have driven Sage's truck with the lowers and it is truley amazing how smooth the steering is.He has been beating on the truck and taering it down for inspection after every thrashing and has seen no wear.He just got back from Baja after some more thrashing.That truck is a real work horse.
Old Sep 9, 2009 | 11:16 PM
  #68
grishfish's Avatar
I'm glad to hear your experience with the Carlis is good. I'm about to swap my moog lowers with something else. I'm not sure what I'll be replacing it with, but it's gotta be grease-able.
Is there anything I can do to the Carlis, while I'm down there, to ensure they're working properly? Without a micrometer, I'm not sure what sort of technical inspection I can make after I take them out. Any ideas?
Old Sep 13, 2009 | 03:42 PM
  #69
15 Digger's Avatar
Dynatrac now has lower balljoints for our trucks, greasable similar price to Carli, ouch.
Old Sep 13, 2009 | 03:48 PM
  #70
15 Digger's Avatar
Dynatrac and Carli at this site. www.8lugtruckgear.com upper and lower.
Old Sep 13, 2009 | 10:30 PM
  #71
bradler's Avatar
carlis are $550 just for the two lowers. dynatracs are $599 for four, uppers and lowers, with the lowers being ~$300.
Old Sep 14, 2009 | 11:57 AM
  #72
rogers259's Avatar
But the Carli's are not going to be ready till Late November(According to the Carli website)...Or is this info incorrect and the Carli lowers are available now?????
Old Sep 14, 2009 | 03:33 PM
  #73
15 Digger's Avatar
I thought for 2 but four sounds alot better to me. Now maybe the others will lower prices, nothing like competition.
Old Sep 16, 2009 | 08:43 AM
  #74
Skyd Ram's Avatar
Hey,
That's my website!
Anyhow, the Carli lowers should be out in November and the Dynatrac hopes to start shipping them in a few weeks.
Old Sep 16, 2009 | 09:11 AM
  #75
Skyd Ram's Avatar
I know alot of you have heard the whole alignment checks out story from the tech, but what kind of alignment numbers are they giving you? These trucks are very sensitive to caster. My 07 truck was hard to keep in the lane when it was new whereas my 05 truck on 37's drove straight down the road. The dealerr said that the alignment was in spec and that I should let the front end "break in". So I test drove a truck on their lot with 4 miles on it and it drove fine. I guess that one had a shorter "break in" period?
Anyhow, it turns out that the caster was around 2 degrees. I set it to 4 degrees myself and it improved quite a bit.
On another note, because of the amount of force that it takes to seat the ball joints in some trucks, I have heard of some moog ball joints being crushed a bit during install that also may cause the problem.
