New to the deisels!!!!!!
Old Aug 16, 2006 | 12:42 AM
redarmyracer's Avatar
I am selling my current truck, a Dodge Dakota, and getting a real truck. Hopefully I can still find one. A 2006 Dodge cummins 2500, three pedals, and a Jake Brake.
I really want it cause well I WANT IT!!!!
Here is my deal though, My current Dakota only gets about 17mpg, and I travel throughout Michigan A LOT. So, a much bigger truck that can get near the same mpg's and tow a house sounds good. What would be the best place to start peformance parts after I ge the truck? I want more mpg's and MORE power. The problem is that, like everything else, the question is "How deep are your pockets?" I do not have 50 grand extra to biuld super truck, like I do with other toys, but a good idea to start would help???
Thanks,
Kevin
If you're into quads, check out 'trx450r.org', or 'Michigandirtslingers.com'
Old Aug 16, 2006 | 07:22 AM
HappyGA's Avatar
well, you will not want a 3rd gen unless you get an 03 or 04, but I think from the way it sounds, financially, you will want to go with a 98.5-02 model years, and they get great mileage with a set of injectors, and a timing box.
For about $ after the purchase of the truck, you can have it getting around 20MPG pretty easily, and that was my 4x4, QuadCab, only thing I had on it was intake, 4" exhaust, and SMARTY.
Old Aug 16, 2006 | 08:13 AM
dogger's Avatar
Originally Posted by redarmyracer
... My current Dakota only gets about 17mpg, and I travel throughout Michigan A LOT. So, a much bigger truck that can get near the same mpg's and tow a house sounds good. ...
Unfortunately with the 06 Cummins the mileage tends to suffer as the EPA has determined that NOX output is more obnoxious than unburned hydrocarbons; hence mileage is going to suffer. Add 4WD and another reduction in mileage. Also in the winter time up there fuel economy is going to decease on winter blend diesel. A late model 2nd gen truck my be more to your liking and it still has the Cummins engine and with a few mods is compareable to the 3rd gen trucks. Having said that if you want new then an 06 - 07 are your only options. Good luck!
L8r,.............dogger
Old Aug 21, 2006 | 09:49 PM
red47's Avatar
My '06 auto is bone stock and I replaced an '00 Dakota (4.7). The Dakota was also getting around 17. I got the Ram for the same reason as yourself - I wanted it! (and the deals were too good to pass) Anyway, I currently have around 4,000 miles on it and the mileage is increasing. Initially it was 15.5, then 16, 16.5, 17, and the last two tanks have been 17.8. I travel about 70-80 miles per day at around 80% highway. I stay around 65 mph most of the time and I flog it when I need to. (I swear it seams that a periodic flooring of the go-pedal will increase your fuel mileage) I can't help you with performance gains but I hope this gives you an idea of what a transition from the Dak to the Ram will be like! One last thing, don't be fooled into thinking your overhead console is giving you an accurate reading. Mine consistently reads 2 mpg more than what I hand calculate.
grishfish
113
Mar 3, 2013 10:53 PM
OOPS
Aug 28, 2004 07:15 PM
powerwagon440
Apr 19, 2003 07:19 AM
midwestdually
Mar 21, 2003 09:06 AM
akchameleon
Mar 19, 2003 12:39 AM
