Need to know the name of this part..
Old Feb 20, 2011 | 06:38 PM
vcoyle's Avatar
I have diesel gushing out of one of the copper lines that goes into the engine. It's right after the fuel filter and sits on the right side of the engine. It is the 3rd line back on the engine. I was driving to church this morning and when I got to church I started smelling diesel inside the truck and as I parking I noticed smoke coming out on the side of the truck. I cut off the engine and lifted the hood to see nothing wrong, but I noticed diesel dripping from the wheel well. After this I had someone try to crank the engine and noticed the diesel squirting out from this line. I don't know what to call it when I went to all of the auto stores nearby. I have removed it from the truck and found where it is leaking, I'm hoping the dealer will have this part. Thanks for the help.
Old Feb 20, 2011 | 08:37 PM
1-2-3's Avatar
Just a plain ole guy
It sounds like an injector line. Common failure on an 06. Any dealer will stock them. There might be some special tools to change one, but I'm not sure. I am sure that you need to NOT drive it till it's fixed and you need to make sure the blue clamps on them are tight at all times. I check mine every few oil changes.
Old Feb 20, 2011 | 11:23 PM
vcoyle's Avatar
Thanks for the name! Mine will not crank, I'm assuming b/c of this issue. If I remember correctly, I think mine is the third one back and I found a site that said to call the Cummins shop to see if they carry this b/c it will be cheaper than a dealer. I will be sure to check this more often this is the 2nd time in 2 months I have been down for a pretty major issue.
Old Feb 21, 2011 | 05:47 AM
Mexstan's Avatar
I am confused about this pipe being on the RIGHT side of the engine. There are no fuel lines on the right side of the engine, only the left.
Old Feb 21, 2011 | 07:09 AM
vcoyle's Avatar
Right side if you are looking at the engine, or it's on the driver's side.
Old Feb 21, 2011 | 08:39 AM
OldDodgeOwner's Avatar
Here's a thread to look at. There's pictures on page 2 of the injector lines. Like was said above, this is a common issue.
https://www.dieseltruckresource.com/...t247239p2.html
Old Feb 22, 2011 | 10:08 PM
vcoyle's Avatar
exactly my problem... it's fixed now. thanks for all of your help. had to pay $60 from the dealer.
Old Feb 22, 2011 | 10:58 PM
AH64ID's Avatar
The common failure is the 4th line, but the 1st one is easily missed when counting as it comes off the front of the rail, not the top.
Just ensure you order the correct one.
Montana2x2
Oct 14, 2009 07:54 PM
bigragu
Nov 25, 2007 08:53 AM
hamilton71801
Aug 8, 2007 03:00 PM
blackdiesel
Oct 9, 2005 09:14 AM
