Need to build an adjustable boost elbow... questions..
Old Jan 15, 2009 | 08:33 AM
AH64ID's Avatar
In order to keep my drive pressure in check I want my WG back in the picture. I am going to run a line from the intake to the OE WG, and set it at about 35psi..
In order to make the install look clean I would like to use an adjustable boost elbow with 1/8" NPT on both side, vs the usual 1/8/ NPT x hose barb... I have been unable to find one for purchase so I plan to make one..
While the concept seems straight foreword I haven't ever looked at one up close. So some questions.
The adjutability just comes from not allowing full air to flow, thus reducing the pressure??
The adj elbows are just off the shelf 90*'s that have been drilled and tapped for a plug?
How tall is the plug, and how much of the fitting gets tapped (i.e. from the mount to the bend? just the bend?)
Thanks for all the help.
Old Jan 15, 2009 | 10:05 PM
jballou's Avatar
I didn't know that an adjustable elbow was a possibility to use on 05's? Enlighten or correct me. Sorry no further help.
Old Jan 16, 2009 | 08:42 AM
AH64ID's Avatar
The WG it self is the same as 03-04, but instead of having a constant air supply like 03-04 it gets its air from an electronically controlled solenoid. (how we get 28-32psi from a 22psi WG). So if you take the solenoid out of the picture you can control the WG with an adjustable elbow and get more (or less) boost...
Hdog
Oct 27, 2014 10:52 AM
AH64ID
Jan 15, 2009 07:39 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
turbo dreams
Jun 1, 2005 02:49 PM
