Need advice
Fill out your signature so people will know what your driving.
Are you experiencing any symptoms??? Or just getting the code.
you are a registered user, so you can use the search function and learn all bout what 0628 means. I am pretty sure it is a lift pump, and if you have the funds to upgrade your fuel system, then now is a good time to do it.
Last edited by BJS Enterprises; Sep 4, 2010 at 03:19 PM. Reason: clarification to message
P0628-LOW VOLTAGE DETECTED AT THE
FUEL LIFT PUMP . . . . . . . . . . . . . . . . . . . .9-1433
² When Monitored:
While the key is on.
² Set Condition:
The commanded signal to the fuel lift pump circuit in the TIPM does not match the feedback signal from the
fuel lift pump circuit.
Possible Causes
WIRING HARNESS
TIPM
FUEL LIFT PUMP CONTROL CIRCUIT SHORTED TO EXTERNAL VOLTAGE
FUEL LIFT PUMP CONTROL CIRCUIT OPEN
FUEL LIFT PUMP GROUND CIRCUIT OPEN
FUEL LIFT PUMP GROUND CIRCUIT SHORTED TO EXTERNAL VOLTAGE
ECM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE -
DIAGNOSIS AND TESTING)
Diagnostic Test
1. POWER AT TPIM
Using a voltmeter, measure the voltage on the Battery Supply wire to the TIPM.
Turn the ignition on, engine off.
Does the voltmeter show battery voltage?
No >> Fix or replace the open circuit in the Battery Supply Circuit. Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC
CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
Yes >> Go To 2
2. DAMANGED WIRING HARNESS
Turn Ignition off.
Disconnect the ECM and TIPM connectors. Inspect the connectors for signs of damage or corrosion.
NOTE: Check connectors - Clean/repair as necessary.
Are any pins damaged?
Yes >> Fix or replace the harness
No >> Go To 5
3. FUEL LIFT PUMP CONTROL CIRCUIT OPEN
Using an ohmmeter, measure the resistance of the lift pump control circuit between the ECM connector and the
TIPM connector.
Is the resistance less than 10 Ohms?
Yes >> Go To 4
No >> Repair the open ground circuit.
9 - 1434 ENGINE - ELECTRICAL DIAGNOSTICS - DIESEL DR
4. FUEL LIFT PUMP CONTROL CIRCUIT SHORTED TO EXTERNAL VOLTAGE
Using a voltmeter, measure the voltage between battery negative and the lift pump control circuit at the TPIM connector.
Is the voltage greater than 1 volt?
No >> Go To 5
Yes >> Fix or replace the harness.
5. FUEL LIFT PUMP CONTROL CIRCUIT SHORTED TO OTHER CIRCUITS
Using an ohmmeter, measure the resistance between the lift pump control circuit in the ECM connector and all other
circuits in the ECM connectors.
No >> Go To 6
6. FUEL LIFT PUMP CONTROL CIRCUIT SHORTED TO EXTERNAL VOLTAGE
Connect the ECM and TIPM connectors.
Using a back probing tool 6801, back probe the lift pump control circuit in from TIPM connector.
Toggle the lift pump actuator with the Electronic Service Tool.
Using a 12 volt test light connected to battery negative, check the lift pump circuit at the TIPM connector.
NOTE: The test light must illuminate brightly.
Compare the brightness to that of a direct connection to the battery.
Does the test light cycle on and off and illuminate brightly?
No >> Replace the ECM
Yes >> Go To 7
7. FUEL LIFT PUMP DRIVER CIRCUIT SHORTED TO OTHER CIRCUITS
Using a back probing tool, back probe the lift pump control circuit in the TIPM connector.
Toggle the lift pump actuator with the scan Tool.
Using a 12 volt test light connected to battery negative, check the lift pump control circuit at the TIPM connector.
Yes >> Test complete.
Perform Intermittent Condition test. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No >> Replace the TPIM
That is out of the 06 factory service manual.
² When Monitored:
² Set Condition:
Possible Causes
WIRING HARNESS
TIPM
ECM
Diagnostic Test
1. POWER AT TPIM
Yes >> Go To 2
Turn Ignition off.
No >> Go To 5
TIPM connector.
Yes >> Go To 4
No >> Go To 5
No >> Go To 6
Yes >> Go To 7
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryan466
Aug 30, 2006 10:10 AM
v8440
14
Sep 7, 2005 08:39 PM
olchevrepl
20
Oct 29, 2002 08:14 PM
