Mystery Part chattering on ignition on
Howdy all,
The part shown below is located on the right inner wheel well. When I turn the ignition key to run but don't start the truck, it makes a chattering noise. Mostly the first start of the day. Doesen't do it all of the time. Not sure if it continues when the truck is running. Its a 03 3500 CTD. My cruise is not working. Is this related to the cruise?
Thanks in advance
Thanks in advance
The pump should pull a vacuum on the resorvior tank to lke a 12hg and if no leak it will shut off.it consist of a motor /crankshaft and a diaphram and a switch.If it pulls down and turns off it's good. Look for a leak at the cruise module on the left fender well.
I found 3 places where the hard tubing had holes worn through. I used aviation grade heat shrink tubing, layering it as I went along. Rerouted the lines to avoid future issues. Test drove it & It works like a champ!!!
Thanks to all you guys for pointing me in the right direction
Duallydog
Nov 12, 2006 08:36 PM
