MPG going to crap!
Old Apr 22, 2010 | 08:26 PM
Undertaker's Avatar
MPG going to crap!
I have a 2007 5.9. Last year I was getting around 17 MPG. it slowly has gotten worse. now I am averaging about 12 to 13. Truck runs like it did new still. Doesn't matter if I am towing 7000 or just driving. 12 to 13
Old Apr 22, 2010 | 08:45 PM
rip 112's Avatar
Seems like a dumb question but are you keeping up with your oil and filter changes? Air filter? Codes??? Fuel filter?
Old Apr 23, 2010 | 08:15 AM
Lost Lake's Avatar
Where are you getting the mpg numbers? Hand calculating? Do you have a loose hose on your fuel tank? Pin hole in the tank? Leaking fuel somewhere?
Maybe the neighbor has a diesel and he siphons your fuel off at night?
Old Apr 24, 2010 | 09:14 PM
Undertaker's Avatar
Yeah I am up on all my filters. I actually just put on a stage 2 AFE intake kit and a Afe bladerunner manifold to see if that would help. Still nothing. I have checked for any leaks and there are none. I am at a loss for words
Old Apr 24, 2010 | 09:34 PM
NickBeek's Avatar
Have you checked for dragging brakes? Are you doing more short trips now? Where are you buying fuel? Do you have any white smoke or rough idle first start of the day?
Old Apr 25, 2010 | 01:24 PM
Undertaker's Avatar
I usually get my fuel at sheetz or citgo. But now that you mention it some mornings it seems like it's not idling real smooth.
Old Apr 25, 2010 | 04:34 PM
Load Hauler 04's Avatar
Have you taken it to the dealership for any reason. If they flashed the computer ( which they will do when you take it in for any reason ) and put a update in it your milage will suffer. I had the dealership replace a fuel lift pump under warrenty ( after failure ) and they flashed my computer and told me it was new software,update. My mileage dropped almost 4 MPG . Had to go to Cummins and have them reset the original parameters to get my mileage back , cost me 250.00 but it was worth it
Old Apr 25, 2010 | 05:09 PM
NickBeek's Avatar
If you have white smoke and a rough idle on the first start of the day, along with reduced fuel economy, you may have an injector going south on you. My truck had those symptoms and new injectors cleared them up.
cmac
Jul 15, 2009 11:20 AM
Jeff5886
18
Jul 15, 2009 09:45 AM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
Common
Sep 7, 2006 06:31 AM
