MPG's went to crap
Old Jun 30, 2009 | 04:35 PM
cmac's Avatar
MPG's went to crap
so my MPG's went down to 13-14 from 17-18..... i have a new overflow valve, clean air filter, i only let it idle long enough to cool down the turbo. my driving habits havnt changed. any ideas??
Old Jun 30, 2009 | 05:35 PM
Bluedually4x4's Avatar
When did you change the fuel filter last?
Old Jul 1, 2009 | 07:19 AM
patdaly's Avatar
As Blue said, fuel filter and pre-filter can change your mileage drastically........ Mine jumped almost 4 MPG after a bout with a blocked pre-filter.
If that doesn't do it, time to get a fuel pressure gauge on there and test the LP.
Old Jul 1, 2009 | 07:49 AM
cmac's Avatar
i cant believe i overlooked that.... it was changed probably 9 months ago or so when my wife moved our stuff down here, it had cracked on the interstate and she limped it to a shop who replaced it. i will try to get a new one on there tonight. i know it has been posted before so can someone point me to the instructions on how to clean the pre filter? thanks
Old Jul 1, 2009 | 09:58 AM
infidel's Avatar
Prefilter cleaning> http://dodgeram.org/tech/dsl/filter/pre-filt_clean.htm
Fuel pressure gauge> http://www.cumminsforum.com/forum/94...-12-valve.html
Old Jul 1, 2009 | 11:24 AM
cmac's Avatar
thanks infidel
Old Jul 4, 2009 | 12:06 PM
cmac's Avatar
so i cleaned and changed that...... i found it much easier to remove the two nuts holding the brake fluid resivoir on and set it down a little farther on the inner fender...... it gives you much more room to get at the filter/pre filter. i also didnt spill a drop of fuel when changing the filter.
Old Jul 14, 2009 | 10:48 PM
chainzaw's Avatar
Is the truck blowing more smoke? You could check to see if you have a boost leak. If you are leaking air out one of the intercooler boots that will cause the truck to burn a lot richer. How fast did your milage go down hill? Are we talking over night or over a month or two?
Old Jul 15, 2009 | 11:20 AM
kawi600's Avatar
I have a fuel pressure gauge and I see 24+ psi. All the mods in my sig and mileage is still 11/16. abysmal.
Just installed a 215 pump hoping that was the culprit. Nada.
driving me crazy.
Undertaker
Apr 25, 2010 05:09 PM
Jeff5886
18
Jul 15, 2009 09:45 AM
scoggins
Jul 24, 2008 08:41 PM
VikingDiesel
Aug 12, 2007 10:10 PM
drew03
76
Feb 6, 2006 07:57 AM
