Should I just watch the voltmeter to see when my alt is going to crap out?
Old Sep 6, 2006 | 07:57 PM
Common's Avatar
I had a voltmeter on it yesterday with the headlights and wipers on I was @ 14.0 and with the heat on full blast it was @ 13.8... a volt or so low... should I be prepared or not sweat it?
I was trying to trace my headlight flickering problem...
Terminals are clean, new batteries (Optimas)... wiring looks good...
I'm assuming its the alt.
Old Sep 6, 2006 | 08:39 PM
Geico266's Avatar
14 volts at idle is pretty good. Have you tried replacing the brushes? Check out Larry B's. He has replacement brushes at a good price.
I would guess you have a headlight swtich or headlight relay problem.
Old Sep 6, 2006 | 09:58 PM
Common's Avatar
I would guess you ahve a headlight swtich or headlight relay problem.
Thanks...
A headlight switch could cause that?
You have a part # or price?
Old Sep 7, 2006 | 04:22 AM
kd460's Avatar
Put the brushes in your glove box. That way it's garanteed you won't need them.
There is no relay in the headlight circuit (but it is a good idea to put one in there), so I would suspect either a bad switch or something in the headlight wiring.
The first thing I would look for is a bad ground. Check out fostertruck.com for the brushes. Are you sure the flickering is not your heater grid kicking on and off? KD
Old Sep 7, 2006 | 06:31 AM
Common's Avatar
Nah, its not the grids...
I'm gonna go ****** up a new switch today...
Undertaker
Apr 25, 2010 05:09 PM
racerdude_9
Nov 16, 2009 12:52 AM
rynelson85
Feb 5, 2008 02:00 AM
SILVERSLEEPER
16
Jan 5, 2008 11:02 AM
